i.MX6S h.264 encoding
3,048件の閲覧回数
dmitryovsyannik
Dear i.MX experts!
Does i.MX6S supports h.264 1080p encoding? Freescale documentation so controversal...
ラベル(4)
タグ(2)
2 返答(返信)
1,808件の閲覧回数
ZeeFrench
Hello Dmitry,
Guess the confusion is coming from the fact VPU (video encoder and decoder bloc) is an option, according to http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6S&tab=Buy_Parametric_Tab&fromSea... not available on S1 and S4, please check automotive datasheet for complete list of option : http://www.freescale.com/files/32bit/doc/data_sheet/IMX6SDLAEC.pdf?fpsp=1&WT_TYPE=Data Sheets&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation (or consumer and industrial but VPU is on all of those).
You could encode in software (make sure you use neon) but for that resolution at a very low frame rate, better use the VPU enabled part numbers.
Best regards, Philippe.
1,808件の閲覧回数
dmitryovsyannik
Thanks, Philippe!
Now everything is clear. Yes, I need hardware acceleration, so I will use part with VPU.
