i.MX6 multiple video streams
1,717 次查看
--claus
I want to playback multiple video streams on imx6 to multiple independent displays.
What are the technical limitations on imx6 in terms of
  • number of concurrent independent video streams
  • resolution per stream
  • frame rate per stream
when using Windows or Linux OS?
Claus
标签 (6)
1,459 次查看
justin_jiang
I.MX6Q can support 4 independent displays. i.MX6S can support 2 independent displays.
Support two 1080p@24fps independent video.
using Linux for the test.
