[i.MX6]compile error of weston for GPU-vivante
863 次查看
andyyang
Hi everyone
I want to build weston for GPU-vivante at i.MX6 platform,but i run into compile error of weston for GPU-vivante
I'm following these steps to build Wayland-Weston for i.MX6 and get stuck at step 7(Building Weston).
(https://community.freescale.com/docs/DOC-95380)
Is there required file(ex .pc) for pkgconfig folder?[export PKG_CONFIG_PATH=$WLD/lib/pkgconfig/:$WLD/share/pkgconfig/]
Could you give some advice?
[compile error]
Package requirements (egl >= 7.10 gles2) were not met
Andy
标记 (3)
621 次查看
jimmychan
Which BSP are you using?
Please download the latest BSP and BSP documentation from here:
i.MX 6 Series Software and Development Tool R|Freescale
