i.MX6 ULL Current
i.MX6 ULL Current
ban45
Hello
The current consumption value is required for the calculation of powerdown.
Is the current value listed in6ULL Power Consumption Application Note all right?
I know the current value I am using, but I want to know the minimum current value so that the voltage does not reverse when the voltage drops.
Please tell me a guide.
Are you sure you want to use the values ​​provided in the datasheet?
Please tell me how the MCIMX6ULL_CM evaluation board maintains the sequence.
weidong_sun
Hi Ban,
  About i.MX6ULL Power consumption, you can refer to the application note.
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
---Application Notes
Have a nice day!
B.R,
Weidong
