i.MX6 Solderable System-On-Module
2,332 次查看
durmus
Hi all,
I've been searching the net for an i.MX6 SOM which has an interface that can directly be soldered on a carrier board. Below is an example with a Samsung Exynos processor:
Samsung Exynos4412 ARM Cortex-A9 Quad Core computer on module BOARDCON
There are a bunch of standard form factors such as q7, uq7, etc. But I have not come across what I'm looking for.
Any help would be appreciated. Thanks in advance.
Durmuş
1,947 次查看
SergioSolis
Hello Durmus,
I wouldn't be able to recommend a specific SOM, but we do have several third party companies that have developed their own SOM.
I'm guessing you are looking for a mini-atx or a more standard factor?
1,947 次查看
durmus
Hello SerchMX,
Thanks for your reply. Mini-ATX, which is mainly a 15x15cm in size, would be too large for our cause.
What I'm looking for is about 70mm x 50mm in size that can directly be soldered on a carrier board from its all 4 sides. No edge connectors or board-to-board connectors.
I don't think there is a standard for that. I have come across with these kind of SOMs, but not one with an i.MX6 processor.
If those companies you mentioned have built a something similar, we might be interested in them.
