i.MX6 FEC fifo overrun
torus1000
Contributor V
I used yocto L3.14.38 for i.MX6Q-SabreSD then measured FEC performance with iperf command.
I believed FEC patch already applied so fifo overrun suppressed with proper pause frames.
https://patchwork.kernel.org/patch/1971731/
But FEC performance looked far poor than 450Mpbs and fifo overrun continuously occurred.
https://boundarydevices.com/i-mx6-ethernet/
Is there any control bit to ignore pause frame? (Which registers should I check first?)
How can I improve FEC performance to avoid overrun?
Thanks.
Tags (3)
weidong_sun
Hello torus1000,
     We have a description on FEC speed in Errata, see following, please!
Hope the information is helpful for you!
Weidong
