i.MX6 CPU cache.
i.MX6 CPU cache.
satoshishimoda
Senior Contributor I
Hi community,
I have some questions about i.MX6S CPU cache.
Please see the questions as following.
[Q1]
Actually, i.MX6S cache is changed from invalid to valid when memory access by USB or Ethernet.
It is not expected behavior, so our partner want to find a solution to avoid this issue.
Then, could you let me know the condition to change the cache invalid -> valid?
[Q2]
Could you let me know the condition to accommodate the cache and memory when cache data and memory data is different?
Is there a possibility to satisfy the condition when a peripheral accesses to memory?
Satoshi Shimoda
Labels (2)
igorpadykov
Hi Satoshi,
please look at link below and SDK example armv7_cache.c
https://community.freescale.com/thread/315745
i.MX 6Series Platform SDK : Bare-metal SDK
Caches operation is well described in ARM (www.arm.com)
document DDI0388H_cortex_a9_r4p0_trm.pdf
chip
