i.MX6 Android camera auto focus handler
2,953 次查看
pierrelgcb
Good morning,
Working on i.MX6 Dual Lite with Android Nougat N7.1.1_1.0.0(kernel 4.1.15).
I integrated camera driver OV5640 with auto focus feature. Video and auto focus work well.
One trouble remains. On camera app, when I touch the screen to focus on a target point, a circle appears but auto focus doesn't start. Auto focus only works on app launch/wake up.
Problem comes from file : kernel_imx/drivers/media/platform/mxc/capture/ov5640_mipi.c (attached file)
function : ioctl_s_ctrl - V4L2 sensor interface handler for VIDIOC_S_CTRL ioctl
The function handler is never called. How can I register/link it to screen touch event ?
Pierre
Original Attachment has been moved to: ov5640_mipi.c.zip
标签 (3)
2,638 次查看
diegoadrian
Hello Pierre,
This problem is more related with OV5640 driver, and unfortunately, we cannot help you with this problem. In this case, I recommend you to go with Omnivision.
Technical Support | Support | OmniVision
I apologize for the inconvenient.
Diego.
2,639 次查看
diegoadrian
Hello Pierre,
Diego.
2,638 次查看
pierrelgcb
Hello Diego,
Thanks for the advice.
Pierre
2,638 次查看
frank_zhang
Hi Pierre,
     For this case, maybe you can try to use our professional support Professional Support for Microcontrollers|NXP, Thank you!
Frank
