i.MX 8M Plus EVK
i.MX 8M Plus EVK
6,149 次查看
kirankumar007
HI,
Am usingi.MX 8M Plus EVK and purchased DTSTREAM-ST(DSTRMST-KT-0197A) connecting to EVK.Arm developer studio using for Debug,
it showing Failed to coonect any device on the target, Check that the target is connectly connected to the debug probe and powered on.
Its EVK board only DT Stream 20Pin and we stopped booting from eMMC to uboot usinf Debug port.
DT Tream target device also detected
Please tell us what we are missing in procedure.
18 回复数
5,886 次查看
kirankumar007
Hi Rita,
Yes As per your suggestion we did boot mode into serial download.
Please guide us for harware connection with Arm development studio no need of platform configuration creation.
In arm development stuido only we are creating c/c++ project and select debugg with A53-0 and DT Stream and forwarded.
Please guide us DT Stream Compatible with I.MX8MP and Also look With and without JTAG Signals below
I.MX8MPLUS (EVK)
Without JTAG
With JTAG
1.
VTREF
High
High
2.
TMS
High
Low
4.
TCK
Low
Low
6.
TDO
Low
0.5
8.
TDI
High
High
10.
SRTST
High
High
5,733 次查看
Rita_Wang
Hi @kirankumar007 ,
We do not have lisence for this tool, i have test on my colleague's PC with it, it is old,  it spport the i.MX8MM EVK i test it , it works well, and test today for the i.MX8Mp, it is also work well.
We have test on the i.MX8MP EVK board, it also display this error at first.
Here we need to choose "add a new platform", you add 8mp, then it will OK.
If still not work tell me freely
Hope this can do help for you
Wish you have a nice day
Best Regards
Rita
5,653 次查看
NXP_USER_05
1. Which JTAG debugger are you using to connect ?
2. Did you connect the board  (I.MX8MPLUS )Cortex A53_0 after the u-boot ? or else without u-boot?
5,566 次查看
Rita_Wang
See my connection:
I connect the board. Board have default images I download before, I think it is not important, as the board in device mode(download mode).
5,521 次查看
NXP_USER_05
Can you please set the boot mode into Serial Download Mode ,after that try to connect the board once through JTAG.
Please share the pictures what you are getting after setting into Serial Download mode and try to connect the board (I.MX8MPlUS) using JTAG.
5,559 次查看
NXP_USER_05
Hi @Rita_Wang
My question is
Did you connect Board after U-Boot (Booting) has executed or before boot (at power-on reset)?
5,532 次查看
Rita_Wang
Hi @NXP_USER_05 ,
Before power on.
5,519 次查看
NXP_USER_05
Hi @Rita_Wang
1.Could you please clarify what you mean by "Before Power on" .?
2.Does it means Before U-Boot ?If yes ,are you able to connect the board through JTAG without booting from emmc ?
5,379 次查看
Rita_Wang
Hi @NXP_USER_05 ,
You need to download images to emmc first.
Best Regards
Rita
5,721 次查看
kirankumar007
Hi Rita,
Please find attchemnts done as per your suggestion
5,664 次查看
Rita_Wang
Hi @kirankumar007 ,
You can follow this, I attach the step to you.
Best Regards
Rita
5,691 次查看
Rita_Wang
Hi @kirankumar007 ,
Are you using this botton
Best Regards
Rita
5,728 次查看
kirankumar007
I.MX8MP EVK JTAG Detection issue.
Default image eMMC booted stopped at Uboot using putty.
After uboot Read following data received in Putty Terminal,
0x470[21] SJC_DISABLE is = 0x1
0x470[23:22] JTAG_SMODE[1:0][1:0] = 0x11
In data sheet
JTAG_SMODE[1:0] = 0x11 means [11 - No debug mode]
From these how to get back in to Debug JTAG mode????
Please guide us
5,885 次查看
kirankumar007
Hi Rita,
Let me know how to check JTAG Enable or Disable w.r.t I.MX8MP(EVK) Detetcion.
Any Register available for checking (Default image available)after uboot in EVK.
We have Custom board with i.MX8MP no default image is loaded.
Is it possible cutom board without any default image JTAG Access is possible????
Am not Found combination with DTsream -ST and I.MX8MP and arm development studio
Please guide us
6,090 次查看
Rita_Wang
Sorry for we do not have the experience using DTSTREAM-ST, here is the step you can try and check, I search it in the network :
1. Verify Hardware Setup
2. Update DSTREAM-ST Firmware
Arm DS automatically checks for firmware updates when connecting to DSTREAM-ST.
If prompted, allow the firmware update.
You can also manually update via the Debug Hardware Firmware Installer in Arm DS.
3. Adjust JTAG Timeout Settings
4. Check Debug Configuration in Arm DS
5. Initialization Script
6. Close Conflicting Applications
7. Use Latest Arm DS Version
Or you can tell us why you need do this test, what problem you met.
5,986 次查看
kirankumar007
We testing in EVK TDO is giving 0.5v Continous(Working on 1.8V)
Any procedure to test after uboot registers like secure boot,boot configurations.
With same setup I.MX6 DUAL board is working fine without any change.
Please guide us EVK only having set of problem during JTAG Detection???
5,959 次查看
Rita_Wang
Hi @kirankumar007 ,
1\ EVK TDO is giving 0.5v Continous means JTAG chain is broken or misconfigured.
2\Compare with i.MX6 Working Setup
  • i.MX6 may not enforce secure boot or restrict JTAG access by default.
  • i.MX 8M Plus has more aggressive security defaults and CoreSight topology.
3\Recommended Debug Procedure
Power off EVK, connect DSTREAM-ST with correct voltage reference.
Set boot switches to serial downloader or minimal U-Boot.
Power on EVK, verify TDO voltage rises to ~1.8V.
In Arm DS:
Disable JTAG timeouts.
Set SCC_TIMEOUT=10000000 in environment.
Use correct .rcf or .sdf file for i.MX 8M Plus.
Try connecting using CoreSight Access Tool or Arm DS Debug Configurator.
4,898 次查看
NXP_USER_05
Hi @Rita_Wang ,
1. On the i.MX8M Plus EVK, LPDDR4 memory is used. However, on our custom board, we are using DDR4 memory (Part No: MT40A1G16RC-062EIT:B).
2. we had build U-Boot in standalone environment by seeing I.MX porting guide,and followed the below procedure mentioned.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Manually-build-Boot-binary-for-i-MX8M-Mi...
3. whenever we tried to boot from fspi ,we are facing the below mention error.
4. we also download the ddr_timing.c from DDR TOOL.
5. While generating images for the i.MX8M Plus LPDDR4 EVK using the Yocto BSP, we are able to successfully generate SD card, F SPI, and boot binary images.
However, when we try to generate images for the i.MX8M Plus DDR4 configuration, it fails to generate the F SPI images and shows an error indicating that only SD and NAND are supported.
can you please guide us regarding this DDR4.
%3CLINGO-SUB%20id%3D%22lingo-sub-2171888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%3CSTRONG%3E%20i.MX%208M%20Plus%20EVK%20%E5%B9%B6%E8%B4%AD%E4%B9%B0%E4%BA%86%20DTSTREAM-ST%20(DSTRMST-KT-0197A)%3C%2FSTRONG%3E%20%EF%BC%8C%E7%94%A8%E4%BA%8E%E8%B0%83%E8%AF%95%E8%BF%9E%E6%8E%A5%E5%88%B0%20EVK.arm%3CSTRONG%3E%20%E5%BC%80%E5%8F%91%E8%80%85%E5%B7%A5%E4%BD%9C%E5%AE%A4%EF%BC%8C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%AE%83%E6%98%BE%E7%A4%BA%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%E4%B8%8A%E7%9A%84%E4%BB%BB%E4%BD%95%E8%AE%BE%E5%A4%87%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E7%9B%AE%E6%A0%87%E6%98%AF%E5%90%A6%E5%B7%B2%E8%BF%9E%E6%8E%A5%E8%87%B3%E8%B0%83%E8%AF%95%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%B9%B6%E5%B7%B2%E5%BC%80%E6%9C%BA%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E7%9A%84%20EVK%20%E6%9D%BF%E5%8F%AA%E6%9C%89%20DT%20Stream%2020Pin%EF%BC%8C%E6%88%91%E4%BB%AC%E5%81%9C%E6%AD%A2%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E7%AB%AF%E5%8F%A3%E4%BB%8E%20eMMC%20%E5%90%AF%E5%8A%A8%E5%88%B0%20uboot%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%98%E6%A3%80%E6%B5%8B%E5%88%B0%20DT%20Tream%20%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E5%9C%A8%E7%A8%8B%E5%BA%8F%E4%B8%8A%E6%9C%89%E5%93%AA%E4%BA%9B%E9%81%97%E6%BC%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E1.%3CSTRONG%3Ei.MX8M%20Plus%20EVK%3C%2FSTRONG%3E%20%E4%BD%BF%E7%94%A8%3CSTRONG%3ELPDDR4%3C%2FSTRONG%3E%E5%86%85%E5%AD%98%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%3CSTRONG%3E%E5%AE%9A%E5%88%B6%E6%9D%BF%3C%2FSTRONG%3E%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20%3CSTRONG%3EDDR4%3C%2FSTRONG%3E%E5%86%85%E5%AD%98%EF%BC%88%E9%83%A8%E4%BB%B6%E5%8F%B7%EF%BC%9A%3CSTRONG%3EMT40A1G16RC-062EIT%3AB%3C%2FSTRONG%3E%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E6%88%91%E4%BB%AC%E9%80%9A%E8%BF%87%E6%9F%A5%E7%9C%8B%20%3CSTRONG%3EI.MX%20%E7%A7%BB%E6%A4%8D%E6%8C%87%E5%8D%97%EF%BC%8C%E5%9C%A8%E7%8B%AC%E7%AB%8B%E7%BB%84%E7%BD%91%20(SA)%20%E7%8E%AF%E5%A2%83%E4%B8%AD%E6%9E%84%E5%BB%BA%E4%BA%86%20U-Boot%EF%BC%8C%3C%2FSTRONG%3E%E5%B9%B6%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FManually-build-Boot-binary-for-i-MX8M-Mini%2Fta-p%2F1116998%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FManually-build-Boot-binary-for-i-MX8M-Mini%2Fta-p%2F1116998%3C%2FA%3E%3C%2FP%3E%3CP%3E3.%20%E6%AF%8F%E5%BD%93%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%BB%8E%20fspi%20%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E9%83%BD%E4%BC%9A%E9%9D%A2%E4%B8%B4%E4%BB%A5%E4%B8%8B%E6%8F%90%E5%8F%8A%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22IMG_20251110_123520.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20251110_123520.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365291iEBD6B849EB3E740A%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%22IMG_20251110_123520.jpg%22%20alt%3D%22IMG_20251110_123520.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E4.%20%E6%88%91%E4%BB%AC%E8%BF%98%E4%B8%8B%E8%BD%BD%E4%BA%86%20ddr_timing.c%E6%9D%A5%E8%87%AA%3CSTRONG%3EDDR%20TOOL%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E5.%20%E5%9C%A8%E4%BD%BF%E7%94%A8%20%3CSTRONG%3EYocto%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%3C%2FSTRONG%3E%E4%B8%BA%20%3CSTRONG%3Ei.MX8M%20Plus%20LPDDR4%20EVK%3C%2FSTRONG%3E%20%E7%94%9F%E6%88%90%E5%9B%BE%E5%83%8F%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E8%83%BD%E5%A4%9F%E6%88%90%E5%8A%9F%E7%94%9F%E6%88%90%20%3CSTRONG%3ESD%20%E5%8D%A1%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3EF%20SPI%3C%2FSTRONG%3E%20%E5%92%8C%3CSTRONG%3E%E5%90%AF%E5%8A%A8%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%9B%BE%E5%83%8F%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%B8%BA%3CSTRONG%3E%20i.MX8M%20Plus%20DDR4%3C%2FSTRONG%3E%20%E9%85%8D%E7%BD%AE%E7%94%9F%E6%88%90%E5%9B%BE%E5%83%8F%E6%97%B6%EF%BC%8C%E5%AE%83%E6%97%A0%E6%B3%95%E7%94%9F%E6%88%90%3CSTRONG%3E%20F%20SPI%20%E6%98%A0%E5%83%8F%3C%2FSTRONG%3E%20%EF%BC%8C%E5%B9%B6%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%EF%BC%8C%E8%A1%A8%E6%98%8E%E4%BB%85%E6%94%AF%E6%8C%81%3CSTRONG%3E%20SD%20%E5%92%8C%3C%2FSTRONG%3E%20%E4%B8%8E%E9%9D%9E%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B0%B1%E8%BF%99%E6%AC%BE%20DDR4%20%E4%B8%BA%E6%88%91%E4%BB%AC%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255591%22%20target%3D%22_blank%22%3E%40Sunil_13%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rita_Wang_0-1761705565593.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1761705565593.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362990i1525311468361975%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rita_Wang_0-1761705565593.png%22%20alt%3D%22Rita_Wang_0-1761705565593.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%85%88%E5%B0%86%E5%9B%BE%E5%83%8F%E4%B8%8B%E8%BD%BD%E5%88%B0%20emmc%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%3C%2FP%3E%3CP%3E1.%E8%AF%B7%E8%AF%B4%E6%98%8E%22Before%20Power%20on%22%20%E7%9A%84%E5%90%AB%E4%B9%89%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%20U-Boot%20%E4%B9%8B%E5%89%8D%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%9C%A8%E4%B8%8D%E4%BB%8E%20emmc%20%E5%90%AF%E5%8A%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E9%80%9A%E8%BF%87%20JTAG%20%E8%BF%9E%E6%8E%A5%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E5%B0%86%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%20JTAG%20%E8%BF%9E%E6%8E%A5%E4%B8%BB%E6%9D%BF%E4%B8%80%E6%AC%A1%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%88%86%E4%BA%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%E5%90%8E%E5%BE%97%E5%88%B0%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20JTAG%20%E8%BF%9E%E6%8E%A5%E6%9D%BF%20(i.MX8MPlus)%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255591%22%20target%3D%22_blank%22%3E%40Sunil_13%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%8E%A5%E9%80%9A%E7%94%B5%E6%BA%90%E5%89%8D%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%20%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%98%AF%E5%9C%A8%E6%89%A7%E8%A1%8C%20U-Boot%EF%BC%88%E5%90%AF%E5%8A%A8%EF%BC%89%E4%B9%8B%E5%90%8E%E8%BF%98%E6%98%AF%E5%9C%A8%E5%90%AF%E5%8A%A8%E4%B9%8B%E5%89%8D%EF%BC%88%E5%BC%80%E6%9C%BA%E9%87%8D%E7%BD%AE%E6%97%B6%EF%BC%89%E8%BF%9E%E6%8E%A5%E4%B8%BB%E6%9D%BF%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E7%9C%8B%E6%88%91%E7%9A%84%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Image%20(40).jpg%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Image%20(40).jpg%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362714i665B555426916613%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Image%20(40).jpg%22%20alt%3D%22Image%20(40).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%9E%E6%8E%A5%E6%9D%BF%E3%80%82%E6%9D%BF%E6%9C%89%E6%88%91%E4%B9%8B%E5%89%8D%E4%B8%8B%E8%BD%BD%E7%9A%84%E9%BB%98%E8%AE%A4%E5%9B%BE%E7%89%87%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E5%B9%B6%E4%B8%8D%E9%87%8D%E8%A6%81%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%9D%BF%E5%A4%84%E4%BA%8E%E8%AE%BE%E5%A4%87%E6%A8%A1%E5%BC%8F%EF%BC%88%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%E6%82%A8%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%EF%BC%9F%3C%2FP%3E%3CP%3E2%E3%80%82%20%E4%BD%A0%E5%9C%A8%3CSTRONG%3E%20u-boot%3C%2FSTRONG%3E%20%E4%B9%8B%E5%90%8E%E8%BF%9E%E6%8E%A5%E4%B8%BB%E6%9D%BF%20(%3CSTRONG%3E%20I.MX8MPLUS)%3C%2FSTRONG%3E%20%3CSTRONG%3ECortex%20A53_0%3C%2FSTRONG%3E%20%E4%BA%86%E5%90%97%EF%BC%9F%20%E6%88%96%E8%80%85%E6%B2%A1%E6%9C%89%20u-boot%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254968%22%20target%3D%22_blank%22%3E%40kirankumar007%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%85%A7%E7%9D%80%E5%81%9A%EF%BC%8C%E6%88%91%E6%8A%8A%E6%AD%A5%E9%AA%A4%E5%8F%91%E7%BB%99%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254968%22%20target%3D%22_blank%22%3E%40kirankumar007%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E8%BF%99%E4%B8%AA%E5%BA%95%E5%BA%A7%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rita_Wang_0-1761275323937.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1761275323937.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362426iA121340FBE61EF07%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rita_Wang_0-1761275323937.png%22%20alt%3D%22Rita_Wang_0-1761275323937.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B8%BD%E5%A1%94%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%8F%82%E8%A7%81%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E5%88%B6%E4%BD%9C%E7%9A%84%E9%99%84%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-10-23%20162412.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-10-23%20162412.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362333i97DE6DF875453291%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-10-23%20162412.png%22%20alt%3D%22Screenshot%202025-10-23%20162412.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-10-23%20162355.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-10-23%20162355.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362334i73BF0E3FA201B298%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-10-23%20162355.png%22%20alt%3D%22Screenshot%202025-10-23%20162355.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-10-23%20162330.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-10-23%20162330.png%22%20style%3D%22width%3A%20356px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362335i7BC78E2E82457386%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-10-23%20162330.png%22%20alt%3D%22Screenshot%202025-10-23%20162330.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EI.MX8MP%20EVK%20JTAG%20%E6%A3%80%E6%B5%8B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20putty%20%E5%9C%A8%20Uboot%20%E5%90%AF%E5%8A%A8%E6%97%B6%E5%81%9C%E6%AD%A2%E4%BA%86%E9%BB%98%E8%AE%A4%E6%98%A0%E5%83%8F%20eMMC%E3%80%82%3C%2FP%3E%3CP%3Euboot%20%E5%90%8E%20%E5%9C%A8%20Putty%20%E7%BB%88%E7%AB%AF%E4%B8%AD%E8%AF%BB%E5%8F%96%E6%94%B6%E5%88%B0%E7%9A%84%E4%BB%A5%E4%B8%8B%E6%95%B0%E6%8D%AE%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kirankumar007_0-1761215976805.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kirankumar007_0-1761215976805.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362321i2BEF9A27E64C891B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kirankumar007_0-1761215976805.jpeg%22%20alt%3D%22kirankumar007_0-1761215976805.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E0x470%5B21%5D%20SJC_DISABLE%20%3D%200x1%3C%2FP%3E%3CP%3E0x470%5B23%3A22%5D%20JTAG_SMODE%5B1%3A0%5D%5B1%3A0%5D%20%3D%200x11%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%3C%2FP%3E%3CP%3EJTAG_SMODE%5B1%3A0%5D%20%3D%200x11%20%E8%A1%A8%E7%A4%BA%20%5B11%20-%20%E6%97%A0%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%BD%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E9%87%8D%E6%96%B0%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%20JTAG%20%E6%A8%A1%E5%BC%8F%3F%3F%3F%3F%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E4%BB%AC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254968%22%20target%3D%22_blank%22%3E%40kirankumar007%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%BF%99%E4%B8%AA%E5%B7%A5%E5%85%B7%E7%9A%84%E8%AE%B8%E5%8F%AF%E8%AF%81%EF%BC%8C%E6%88%91%E5%9C%A8%E6%88%91%E5%90%8C%E4%BA%8B%E7%9A%84%E7%94%B5%E8%84%91%E4%B8%8A%E7%94%A8%E5%AE%83%E6%B5%8B%E8%AF%95%E8%BF%87%EF%BC%8C%E5%AE%83%E5%BE%88%E8%80%81%E4%BA%86%EF%BC%8C%E6%94%AF%E6%8C%81%20i.MX8MM%20EVK%EF%BC%8C%E6%88%91%E6%B5%8B%E8%AF%95%E8%BF%87%EF%BC%8C%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%EF%BC%8C%E4%BB%8A%E5%A4%A9%E5%8F%88%E6%B5%8B%E8%AF%95%E4%BA%86%20i.MX8Mp%EF%BC%8C%E6%95%88%E6%9E%9C%E4%B9%9F%E5%BE%88%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rita_Wang_0-1761032975800.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1761032975800.png%22%20style%3D%22width%3A%20305px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361792i644D050EF44C6F49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rita_Wang_0-1761032975800.png%22%20alt%3D%22Rita_Wang_0-1761032975800.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorRita_Wang_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rita_Wang_2-1761033168345.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_2-1761033168345.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F361794i252C020E0A61F424%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rita_Wang_2-1761033168345.png%22%20alt%3D%22Rita_Wang_2-1761033168345.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image%20(86).png%22%20style%3D%22width%3A%20534px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(86).png%22%20style%3D%22width%3A%20534px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362310i68C9602C1EF6A902%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(86).png%22%20alt%3D%22image%20(86).png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%9C%A8i.MX8MP%20EVK%E6%9D%BF%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%AE%83%E8%B5%B7%E5%88%9D%E8%BF%98%E6%98%BE%E7%A4%BA%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E9%80%89%E6%8B%A9%3CSTRONG%3E%20%22%E6%B7%BB%E5%8A%A0%E6%96%B0%E5%B9%B3%E5%8F%B0%22%3C%2FSTRONG%3E%20%EF%BC%8C%E6%B7%BB%E5%8A%A0%208MP%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Image%20(38).jpg%22%20style%3D%22width%3A%20562px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Image%20(38).jpg%22%20style%3D%22width%3A%20562px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362314i55B8F59F0FD6B206%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Image%20(38).jpg%22%20alt%3D%22Image%20(38).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorRita_Wang_2%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Image%20(39).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Image%20(39).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362316i4D8051F6AC09EF91%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Image%20(39).jpg%22%20alt%3D%22Image%20(39).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorRita_Wang_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%BF%98%E4%B8%8D%E8%A1%8C%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorRita_Wang_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B8%BD%E5%A1%94%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%20I.MX8MP(EVK)%E6%A3%80%E6%B5%8B%E5%99%A8%E7%9A%84%20JTAG%20%E5%90%AF%E7%94%A8%E6%88%96%E7%A6%81%E7%94%A8%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20EVK%20%E4%B8%ADuboot%20%E5%90%8E%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E6%B3%A8%E5%86%8C%E8%A1%A8%E5%8F%AF%E4%BE%9B%E6%A3%80%E6%9F%A5%EF%BC%88%E9%BB%98%E8%AE%A4%E5%9B%BE%E5%83%8F%E5%8F%AF%E7%94%A8%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%9C%89%E5%B8%A6%E6%9C%89%20i.mx8MP%20%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%EF%BC%8C%E6%9C%AA%E5%8A%A0%E8%BD%BD%E9%BB%98%E8%AE%A4%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%BB%98%E8%AE%A4%E5%9B%BE%E5%83%8F%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%AE%9A%E5%88%B6%E6%9D%BF%20JTAG%20Access%EF%BC%9F%EF%BC%9F%3C%2FP%3E%3CP%3EAm%20not%20Found%20%E4%B8%8E%20dtStream-ST%20%E5%92%8C%20I.MX8MP%20%E4%BB%A5%E5%8F%8A%20arm%20%E5%BC%80%E5%8F%91%E5%B7%A5%E4%BD%9C%E5%AE%A4%E7%9A%84%E7%BB%84%E5%90%88%E6%9C%AA%E6%89%BE%E5%88%B0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E4%BB%AC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B8%BD%E5%A1%94%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%A0%B9%E6%8D%AE%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E7%A1%AE%E5%AE%9E%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%9B%E5%85%A5%E4%BA%86%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E4%BB%AC%E4%B8%8E%20Arm%20%E5%BC%80%E5%8F%91%E5%B7%A5%E4%BD%9C%E5%AE%A4%E5%BB%BA%E7%AB%8B%E7%A1%AC%E4%BB%B6%E8%BF%9E%E6%8E%A5%EF%BC%8C%E6%97%A0%E9%9C%80%E5%88%9B%E5%BB%BA%E5%B9%B3%E5%8F%B0%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%AA%E6%9C%89%E5%9C%A8%20arm%20%E5%BC%80%E5%8F%91%E5%B7%A5%E4%BD%9C%E5%AE%A4%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%89%8D%E5%88%9B%E5%BB%BA%20c%2Fc%2B%2B%20%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%BF%E7%94%A8%20A53-0%20%E5%92%8C%20DT%20Stream%20%E9%80%89%E6%8B%A9%20debugg%20%E5%B9%B6%E8%BF%9B%E8%A1%8C%E8%BD%AC%E5%8F%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%90%91%E6%88%91%E4%BB%AC%E4%BB%8B%E7%BB%8D%E4%B8%8E%20I.MX8MP%20%E5%85%BC%E5%AE%B9%E7%9A%84%20DT%20%E6%B5%81%EF%BC%8C%E5%B9%B6%E6%9F%A5%E7%9C%8B%E4%BB%A5%E4%B8%8B%E5%B8%A6%20JTAG%20%E4%BF%A1%E5%8F%B7%E5%92%8C%E4%B8%8D%E5%B8%A6%20JTAG%20%E4%BF%A1%E5%8F%B7%E7%9A%84%20DT%20%E6%B5%81%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2285%22%3E%3CBR%20%2F%3E%3C%2FTD%3E%3CTD%20width%3D%22241%22%3E%3CP%3E%3CSTRONG%3Ei.mx8mplus%20(evk)%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22213%22%3E%3CP%3E%3CSTRONG%3E%E6%97%A0%20JTAG%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22170%22%3E%3CP%3E%3CSTRONG%3E%E5%B8%A6%20JTAG%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2285%22%3E%3CP%3E1.%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22241%22%3E%3CP%3EVTREF%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22213%22%3E%3CP%3E%E9%AB%98%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22170%22%3E%3CP%3E%E9%AB%98%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2285%22%3E%3CP%3E2.%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22241%22%3E%3CP%3ETMS%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22213%22%3E%3CP%3E%E9%AB%98%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22170%22%3E%3CP%3E%E4%BD%8E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2285%22%3E%3CP%3E4.%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22241%22%3E%3CP%3ETCK%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22213%22%3E%3CP%3E%E4%BD%8E%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22170%22%3E%3CP%3E%E4%BD%8E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2285%22%3E%3CP%3E6.%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22241%22%3E%3CP%3ETDO%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22213%22%3E%3CP%3E%E4%BD%8E%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22170%22%3E%3CP%3E0.5%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2285%22%3E%3CP%3E8.%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22241%22%3E%3CP%3ETDI%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22213%22%3E%3CP%3E%E9%AB%98%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22170%22%3E%3CP%3E%E9%AB%98%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2285%22%3E%3CP%3E10.%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22241%22%3E%3CP%3ESRTST%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22213%22%3E%3CP%3E%E9%AB%98%3C%2FP%3E%3C%2FTD%3E%3CTD%20width%3D%22170%22%3E%3CP%3E%E9%AB%98%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254968%22%20target%3D%22_blank%22%3E%40kirankumar007%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E1%5C%20EVK%20TDO%20%E7%BB%99%E5%87%BA%200.5v%20Continuous%20%E6%84%8F%E5%91%B3%E7%9D%80%3CSPAN%20data-slate-fragment%3D%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%3D%22%3EJTAG%20%E9%93%BE%E6%96%AD%E5%BC%80%E6%88%96%E9%85%8D%E7%BD%AE%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-fragment%3D%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%3D%22%3E2Compare%20with%20i.MX6%20%E5%B7%A5%E4%BD%9C%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8Ci.MX6%20%E5%8F%AF%E8%83%BD%E4%B8%8D%E4%BC%9A%E5%BC%BA%E5%88%B6%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E6%88%96%E9%99%90%E5%88%B6%20JTAG%20%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E3%80%82%3C%2FLI%3E%0A%3CLI%3Ei.MX%208M%20Plus%20%E5%85%B7%E6%9C%89%3CSTRONG%3E%E6%9B%B4%E4%B8%A5%E6%A0%BC%E7%9A%84%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%3C%2FSTRONG%3E%E5%92%8C%20%3CSTRONG%3ECoreSight%20%E6%8B%93%E6%89%91%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E3%20%E5%BB%BA%E8%AE%AE%E7%9A%84%3CSPAN%20data-slate-node%3D%22text%22%3E%E8%B0%83%E8%AF%95%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E5%85%B3%E9%97%AD%20EVK%20%E7%94%B5%E6%BA%90%EF%BC%8C%E5%B0%86%20DSTREAM-ST%20%E4%B8%8E%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%8F%82%E8%80%83%E7%94%B5%E5%8E%8B%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E5%B0%86%E5%90%AF%E5%8A%A8%E5%BC%80%E5%85%B3%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E5%99%A8%E6%88%96%E6%9C%80%E5%B0%8F%20U-Boot%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E6%8E%A5%E9%80%9A%20EVK%20%E7%94%B5%E6%BA%90%EF%BC%8C%E9%AA%8C%E8%AF%81%20TDO%20%E7%94%B5%E5%8E%8B%E5%8D%87%E8%87%B3%20~1.8V%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E5%9C%A8%20Arm%20DS%20%E4%B8%AD%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E7%A6%81%E7%94%A8%20JTAG%20%E8%B6%85%E6%97%B6%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E5%9C%A8%E7%8E%AF%E5%A2%83%E4%B8%AD%E8%AE%BE%E7%BD%AE%20SCC_TIMEOUT%3D10000000%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%20.rcf%E6%88%96%20.sdfi.MX%208M%20Plus%20%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20CoreSIGHT%20%E8%AE%BF%E9%97%AE%E5%B7%A5%E5%85%B7%E6%88%96%20Arm%20DS%20%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E5%99%A8%E8%BF%9B%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%9C%A8%20EVK%20TDO%20%E4%B8%AD%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E4%B8%BA%200.5V%EF%BC%88%E5%B7%A5%E4%BD%9C%E7%94%B5%E5%8E%8B%E4%B8%BA%201.8V%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20uboot%20%E6%B3%A8%E5%86%8C%E4%B9%8B%E5%90%8E%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E7%9A%84%E4%BB%BB%E4%BD%95%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E3%80%81%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%8CI.MX6%20DUAL%20%E6%9D%BF%E6%97%A0%E9%9C%80%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%94%B9%E5%8D%B3%E5%8F%AF%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E4%B8%BA%E6%88%91%E4%BB%AC%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%EF%BC%8CEVK%20%E4%BB%85%E5%9C%A8%20JTAG%20%E6%A3%80%E6%B5%8B%E6%9C%9F%E9%97%B4%E5%87%BA%E7%8E%B0%E4%B8%80%E7%BB%84%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%208M%20Plus%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%3CSPAN%20data-slate-fragment%3D%22JTVCJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJwTHE0empWeDVNJTIyJTJDJTIycGFyYUlkeCUyMiUzQTAlMkMlMjJzcmMlMjIlM0ElMjJleHBlcmllbmNlJTIyJTJDJTIyZHN0JTIyJTNBJTIyJUU3JUJCJThGJUU5JUFBJThDJTIyJTJDJTIybWV0YWRhdGElMjIlM0ElMjIlMjIlMkMlMjJtYXRjaGVzJTIyJTNBbnVsbCUyQyUyMnRyYW5zbGF0ZWRCeSUyMiUzQW51bGwlMkMlMjJtZXRhRGF0YSUyMiUzQSU1QiU1RCUyQyUyMnRleHQlMjIlM0ElMjJleHBlcmllbmNlJTIyJTdEJTVEJTdEJTVE%22%3E%20%3CSTRONG%3E%EF%BC%8C%20%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8DTSTREAM-ST%20%E7%9A%84%20%E7%BB%8F%E9%AA%8C%EF%BC%8C%20%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E6%A3%80%E6%9F%A5%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E6%88%91%E5%9C%A8%E7%BD%91%E7%BB%9C%E4%B8%AD%E6%90%9C%E7%B4%A2%E5%88%B0%E4%BA%86%E5%AE%83%20%EF%BC%9A%3C%2FP%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E1.%E9%AA%8C%E8%AF%81%E7%A1%AC%E4%BB%B6%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E2.%E6%9B%B4%E6%96%B0%20DSTREAM-ST%20%E5%9B%BA%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%229Vqn1xn2wG%22%20data-para-id%3D%222%22%3E%E8%BF%9E%E6%8E%A5%20DSTREAM-ST%20%E6%97%B6%EF%BC%8CArm%20DS%20%E4%BC%9A%E8%87%AA%E5%8A%A8%E6%A3%80%E6%9F%A5%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E6%8F%90%E7%A4%BA%EF%BC%8C%E8%AF%B7%E5%85%81%E8%AE%B8%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22pkAEog1vw2%22%20data-para-id%3D%224%22%3E%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20Arm%20DS%20%E4%B8%AD%E7%9A%84%E8%B0%83%E8%AF%95%E7%A1%AC%E4%BB%B6%E5%9B%BA%E4%BB%B6%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E6%89%8B%E5%8A%A8%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22zZ5elkD8AN%22%20data-para-id%3D%225%22%3E3.%E8%B0%83%E6%95%B4%20JTAG%20%E8%B6%85%E6%97%B6%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22xM5l4xer5G%22%20data-para-id%3D%226%22%3E4%E3%80%82%E5%9C%A8%20Arm%20DS%20%E4%B8%AD%E6%A3%80%E6%9F%A5%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%2204AJxB1mwp%22%20data-para-id%3D%227%22%3E5.%E5%88%9D%E5%A7%8B%E5%8C%96%E8%84%9A%E6%9C%AC%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%220j5rrxbN5v%22%20data-para-id%3D%228%22%3E6.%E5%85%B3%E9%97%AD%E5%86%B2%E7%AA%81%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E7%E3%80%82%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%20Arm%20DS%20%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%22JTVCJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjI2NHdrQkViZzU5JTIyJTJDJTIycGFyYUlkeCUyMiUzQTAlMkMlMjJzcmMlMjIlM0ElMjIxLiUyMFZlcmlmeSUyMEhhcmR3YXJlJTIwU2V0dXAlMjIlMkMlMjJkc3QlMjIlM0ElMjIxLiVFOSVBQSU4QyVFOCVBRiU4MSVFNyVBMSVBQyVFNCVCQiVCNiVFOCVBRSVCRSVFNyVCRCVBRSUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyMS4lMjBWZXJpZnklMjBIYXJkd2FyZSUyMFNldHVwJTIyJTdEJTVEJTdEJTJDJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJrMTVhWmtFT3dkJTIyJTJDJTIycGFyYUlkeCUyMiUzQTElMkMlMjJzcmMlMjIlM0ElMjIyLiUyMFVwZGF0ZSUyMERTVFJFQU0tU1QlMjBGaXJtd2FyZSUyMiUyQyUyMmRzdCUyMiUzQSUyMjIuJUU2JTlCJUI0JUU2JTk2JUIwRFNUUkVBTS1TVCVFNSU5QiVCQSVFNCVCQiVCNiUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyMi4lMjBVcGRhdGUlMjBEU1RSRUFNLVNUJTIwRmlybXdhcmUlMjIlN0QlNUQlN0QlMkMlN0IlMjJ0eXBlJTIyJTNBJTIycGFyYWdyYXBoJTIyJTJDJTIyY2hpbGRyZW4lMjIlM0ElNUIlN0IlMjJpZCUyMiUzQSUyMjlWcW4xeG4yd0clMjIlMkMlMjJwYXJhSWR4JTIyJTNBMiUyQyUyMnNyYyUyMiUzQSUyMkFybSUyMERTJTIwYXV0b21hdGljYWxseSUyMGNoZWNrcyUyMGZvciUyMGZpcm13YXJlJTIwdXBkYXRlcyUyMHdoZW4lMjBjb25uZWN0aW5nJTIwdG8lMjBEU1RSRUFNLVNULiUyMiUyQyUyMmRzdCUyMiUzQSUyMkFybSUyMERTJUU1JTlDJUE4JUU4JUJGJTlFJUU2JThFJUE1JUU1JTg4JUIwRFNUUkVBTS1TVCVFNiU5NyVCNiVFNCVCQyU5QSVFOCU4NyVBQSVFNSU4QSVBOCVFNiVBMyU4MCVFNiU5RiVBNSVFNSU5QiVCQSVFNCVCQiVCNiVFNiU5QiVCNCVFNiU5NiVCMCVFMyU4MCU4MiUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyQXJtJTIwRFMlMjBhdXRvbWF0aWNhbGx5JTIwY2hlY2tzJTIwZm9yJTIwZmlybXdhcmUlMjB1cGRhdGVzJTIwd2hlbiUyMGNvbm5lY3RpbmclMjB0byUyMERTVFJFQU0tU1QuJTIyJTdEJTVEJTdEJTJDJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJNWnF5MnhiRUExJTIyJTJDJTIycGFyYUlkeCUyMiUzQTMlMkMlMjJzcmMlMjIlM0ElMjJJZiUyMHByb21wdGVkJTJDJTIwYWxsb3clMjB0aGUlMjBmaXJtd2FyZSUyMHVwZGF0ZS4lMjIlMkMlMjJkc3QlMjIlM0ElMjIlRTUlQTYlODIlRTYlOUUlOUMlRTclQjMlQkIlRTclQkIlOUYlRTYlOEYlOTAlRTclQTQlQkElRUYlQkMlOEMlRTUlODUlODElRTglQUUlQjglRTUlOUIlQkElRTQlQkIlQjYlRTYlOUIlQjQlRTYlOTYlQjAlRTMlODAlODIlMjIlMkMlMjJtZXRhZGF0YSUyMiUzQSUyMiUyMiUyQyUyMm1hdGNoZXMlMjIlM0FudWxsJTJDJTIydHJhbnNsYXRlZEJ5JTIyJTNBbnVsbCUyQyUyMm1ldGFEYXRhJTIyJTNBJTVCJTVEJTJDJTIydGV4dCUyMiUzQSUyMklmJTIwcHJvbXB0ZWQlMkMlMjBhbGxvdyUyMHRoZSUyMGZpcm13YXJlJTIwdXBkYXRlLiUyMiU3RCU1RCU3RCUyQyU3QiUyMnR5cGUlMjIlM0ElMjJwYXJhZ3JhcGglMjIlMkMlMjJjaGlsZHJlbiUyMiUzQSU1QiU3QiUyMmlkJTIyJTNBJTIycGtBRW9nMXZ3MiUyMiUyQyUyMnBhcmFJZHglMjIlM0E0JTJDJTIyc3JjJTIyJTNBJTIyWW91JTIwY2FuJTIwYWxzbyUyMG1hbnVhbGx5JTIwdXBkYXRlJTIwdmlhJTIwdGhlJTIwRGVidWclMjBIYXJkd2FyZSUyMEZpcm13YXJlJTIwSW5zdGFsbGVyJTIwaW4lMjBBcm0lMjBEUy4lMjIlMkMlMjJkc3QlMjIlM0ElMjIlRTYlODIlQTglRTglQkYlOTglRTUlOEYlQUYlRTQlQkIlQTUlRTklODAlOUElRTglQkYlODdBcm0lMjBEUyVFNCVCOCVBRCVFNyU5QSU4NCVFOCVCMCU4MyVFOCVBRiU5NSVFNyVBMSVBQyVFNCVCQiVCNiVFNSU5QiVCQSVFNCVCQiVCNiVFNSVBRSU4OSVFOCVBMyU4NSVFNyVBOCU4QiVFNSVCQSU4RiVFNiU4OSU4QiVFNSU4QSVBOCVFNiU5QiVCNCVFNiU5NiVCMCVFMyU4MCU4MiUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyWW91JTIwY2FuJTIwYWxzbyUyMG1hbnVhbGx5JTIwdXBkYXRlJTIwdmlhJTIwdGhlJTIwRGVidWclMjBIYXJkd2FyZSUyMEZpcm13YXJlJTIwSW5zdGFsbGVyJTIwaW4lMjBBcm0lMjBEUy4lMjIlN0QlNUQlN0QlMkMlN0IlMjJ0eXBlJTIyJTNBJTIycGFyYWdyYXBoJTIyJTJDJTIyY2hpbGRyZW4lMjIlM0ElNUIlN0IlMjJpZCUyMiUzQSUyMnpaNWVsa0Q4QU4lMjIlMkMlMjJwYXJhSWR4JTIyJTNBNSUyQyUyMnNyYyUyMiUzQSUyMjMuJTIwQWRqdXN0JTIwSlRBRyUyMFRpbWVvdXQlMjBTZXR0aW5ncyUyMiUyQyUyMmRzdCUyMiUzQSUyMjMuJUU4JUIwJTgzJUU2JTk1JUI0SlRBRyVFOCVCNiU4NSVFNiU5NyVCNiVFOCVBRSVCRSVFNyVCRCVBRSUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyMy4lMjBBZGp1c3QlMjBKVEFHJTIwVGltZW91dCUyMFNldHRpbmdzJTIyJTdEJTVEJTdEJTJDJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJ4TTVsNHhlcjVHJTIyJTJDJTIycGFyYUlkeCUyMiUzQTYlMkMlMjJzcmMlMjIlM0ElMjI0LiUyMENoZWNrJTIwRGVidWclMjBDb25maWd1cmF0aW9uJTIwaW4lMjBBcm0lMjBEUyUyMiUyQyUyMmRzdCUyMiUzQSUyMjQuJUU2JUEzJTgwJUU2JTlGJUE1QXJtJTIwRFMlRTQlQjglQUQlRTclOUElODQlRTglQjAlODMlRTglQUYlOTUlRTklODUlOEQlRTclQkQlQUUlMjIlMkMlMjJtZXRhZGF0YSUyMiUzQSUyMiUyMiUyQyUyMm1hdGNoZXMlMjIlM0FudWxsJTJDJTIydHJhbnNsYXRlZEJ5JTIyJTNBbnVsbCUyQyUyMm1ldGFEYXRhJTIyJTNBJTVCJTVEJTJDJTIydGV4dCUyMiUzQSUyMjQuJTIwQ2hlY2slMjBEZWJ1ZyUyMENvbmZpZ3VyYXRpb24lMjBpbiUyMEFybSUyMERTJTIyJTdEJTVEJTdEJTJDJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjIwNEFKeEIxbXdwJTIyJTJDJTIycGFyYUlkeCUyMiUzQTclMkMlMjJzcmMlMjIlM0ElMjI1LiUyMEluaXRpYWxpemF0aW9uJTIwU2NyaXB0JTIyJTJDJTIyZHN0JTIyJTNBJTIyNS4lRTUlODglOUQlRTUlQTclOEIlRTUlOEMlOTYlRTglODQlOUElRTYlOUMlQUMlMjIlMkMlMjJtZXRhZGF0YSUyMiUzQSUyMiUyMiUyQyUyMm1hdGNoZXMlMjIlM0FudWxsJTJDJTIydHJhbnNsYXRlZEJ5JTIyJTNBbnVsbCUyQyUyMm1ldGFEYXRhJTIyJTNBJTVCJTVEJTJDJTIydGV4dCUyMiUzQSUyMjUuJTIwSW5pdGlhbGl6YXRpb24lMjBTY3JpcHQlMjIlN0QlNUQlN0QlMkMlN0IlMjJ0eXBlJTIyJTNBJTIycGFyYWdyYXBoJTIyJTJDJTIyY2hpbGRyZW4lMjIlM0ElNUIlN0IlMjJpZCUyMiUzQSUyMjBqNXJyeGJONXYlMjIlMkMlMjJwYXJhSWR4JTIyJTNBOCUyQyUyMnNyYyUyMiUzQSUyMjYuJTIwQ2xvc2UlMjBDb25mbGljdGluZyUyMEFwcGxpY2F0aW9ucyUyMiUyQyUyMmRzdCUyMiUzQSUyMjYuJUU1JTg1JUIzJUU5JTk3JUFEJUU1JTg2JUIyJUU3JUFBJTgxJUU3JTlBJTg0JUU1JUJBJTk0JUU3JTk0JUE4JUU3JUE4JThCJUU1JUJBJThGJTIyJTJDJTIybWV0YWRhdGElMjIlM0ElMjIlMjIlMkMlMjJtYXRjaGVzJTIyJTNBbnVsbCUyQyUyMnRyYW5zbGF0ZWRCeSUyMiUzQW51bGwlMkMlMjJtZXRhRGF0YSUyMiUzQSU1QiU1RCUyQyUyMnRleHQlMjIlM0ElMjI2LiUyMENsb3NlJTIwQ29uZmxpY3RpbmclMjBBcHBsaWNhdGlvbnMlMjIlN0QlNUQlN0QlMkMlN0IlMjJ0eXBlJTIyJTNBJTIycGFyYWdyYXBoJTIyJTJDJTIyY2hpbGRyZW4lMjIlM0ElNUIlN0IlMjJpZCUyMiUzQSUyMmowd1pEbGtSQWUlMjIlMkMlMjJwYXJhSWR4JTIyJTNBOSUyQyUyMnNyYyUyMiUzQSUyMjcuJTIwVXNlJTIwTGF0ZXN0JTIwQXJtJTIwRFMlMjBWZXJzaW9uJTIyJTJDJTIyZHN0JTIyJTNBJTIyNy4lRTQlQkQlQkYlRTclOTQlQTglRTYlOUMlODAlRTYlOTYlQjBBcm0lMjBEUyVFNyU4OSU4OCVFNiU5QyVBQyUyMiUyQyUyMm1ldGFkYXRhJTIyJTNBJTIyJTIyJTJDJTIybWF0Y2hlcyUyMiUzQW51bGwlMkMlMjJ0cmFuc2xhdGVkQnklMjIlM0FudWxsJTJDJTIybWV0YURhdGElMjIlM0ElNUIlNUQlMkMlMjJ0ZXh0JTIyJTNBJTIyNy4lMjBVc2UlMjBMYXRlc3QlMjBBcm0lMjBEUyUyMFZlcnNpb24lMjIlN0QlNUQlN0QlNUQ%3D%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E6%88%96%E8%80%85%EF%BC%8C%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E4%B8%BA%E4%BB%80%E4%B9%88%E9%9C%80%E8%A6%81%E5%81%9A%E8%BF%99%E9%A1%B9%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%82%A8%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%3D%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
