i.MX 8M Mini
i.MX 8M Mini
mudherp
I need support from NXP regarding transfer of distro build to the im8mmevk. I have following steps in the IMXLUG.pdf document as shown below: 1) mkdir imx-yocto-bsp 2) cd imx-yocto-bsp 3) repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-gatesgarth -m imx-5.10.9-1.0.0.xml 4) repo sync 5) DISTRO=fsl-imx-xwayland MACHINE=imx8mmevk source imx-setup-release.sh -b build-xwayland 6) bitbake core-image-minimal From the above and from the built directory after bit baking; I get a set of built images in the tmp/deploy directory Therefore: 1) Can you explain to me how I transfer the images to the board using the UUU utility? 2) Can you tell me to build the core-image-minimal for EMMC?
Zhiming_Liu
Q1:
See UUU.pdf:https://github.com/NXPmicro/mfgtools/releases
Q2:
The images built from yocto can be used for sd/emmc, you can choose which device when using uuu
mudherp
We wish to populate the sdk for core-image minimal
We get build errors and have attached the log of the issue
PLEASE CAN YOU PROVIDE ASSIATANCE TO REOLVE THE BUILD ERRORS
mudherp
The log file shows the following errors:
1) ERROR: Unable to remove packages. Command '['/home/mudherp/imx-yocto-bsp/build-xwayland/tmp/work/imx8mmevk-poky-linux/core-image-minimal/1.0-r0/recipe-sysroot-native/usr/bin/apt-get', 'purge', 'nativesdk-glibc-binary-localedata-aa-dj.utf-8', 'nativesdk-glibc-binary-localedata-af-za.utf-8', 'nativesdk-glibc-binary-localedata-an-es.utf-8', 'nativesdk-glibc-binary-localedata-ar-ae.utf-8', 'nativesdk-glibc-binary-localedata-ar-bh.utf-8', 'nativesdk-glibc-binary-localedata-ar-dz.utf-8', 'nativesdk-glibc-binary-localedata-ar-eg.utf-8', 'nativesdk-glibc-binary-localedata-ar-iq.utf-8', 'nativesdk-glibc-binary-localedata-ar-jo.utf-8', 'nativesdk-glibc-binary-localedata-ar-kw.utf-8', 'nativesdk-glibc-binary-localedata-ar-lb.utf-8', 'nativesdk-glibc-binary-localedata-ar-ly.utf-8', 'nativesdk-glibc-binary-localedata-ar-ma.utf-8', 'nativesdk-glibc-binary-localedata-ar-om.utf-8', 'nativesdk-glibc-binary-localedata-ar-qa.utf-8', 'nativesdk-glibc-binary-localedata-ar-sa.utf-8', 'nativesdk-glibc-binary-localedata-ar-sd.utf-8', 'nativesdk-glibc-binary-localedata-ar-sy.utf-8', 'nativesdk-glibc-binary-localedata-ar-tn.utf-8', 'nativesdk-glibc-binary-localedata-ar-ye.utf-8', 'nativesdk-glibc-binary-localedata-ast-es.utf-8', 'nativesdk-glibc-binary-localedata-be-by.utf-8', 'nativesdk-glibc-binary-localedata-bg-bg.utf-8', 'nativesdk-glibc-binary-localedata-bhb-in.utf-8', 'nativesdk-glibc-binary-localedata-br-fr.utf-8', 'nativesdk-glibc-binary-localedata-bs-ba.utf-8', 'nativesdk-glibc-binary-localedata-ca-ad.utf-8', 'nativesdk-glibc-binary-localedata-ca-es.utf-8', 'nativesdk-glibc-binary-localedata-ca-fr.utf-8', 'nativesdk-glibc-binary-localedata-ca-it.utf-8', 'nativesdk-glibc-binary-localedata-cs-cz.utf-8', 'nativesdk-glibc-binary-localedata-cy-gb.utf-8', 'nativesdk-glibc-binary-localedata-da-dk.utf-8', 'nativesdk-glibc-binary-localedata-de-at.utf-8', 'nativesdk-glibc-binary-localedata-de-be.utf-8', 'nativesdk-glibc-binary-localedata-de-ch.utf-8', 'nativesdk-glibc-binary-localedata-de-de.utf-8', 'nativesdk-glibc-binary-localedata-de-it.utf-8', 'nativesdk-glibc-binary-localedata-de-li.utf-8', 'nativesdk-glibc-binary-localedata-de-lu.utf-8', 'nativesdk-glibc-binary-localedata-el-cy.utf-8', 'nativesdk-glibc-binary-localedata-el-gr.utf-8', 'nativesdk-glibc-binary-localedata-en-au.utf-8', 'nativesdk-glibc-binary-localedata-en-bw.utf-8', 'nativesdk-glibc-binary-localedata-en-ca.utf-8', 'nativesdk-glibc-binary-localedata-en-dk.utf-8', 'nativesdk-glibc-binary-localedata-en-gb.utf-8', 'nativesdk-glibc-binary-localedata-en-hk.utf-8', 'nativesdk-glibc-binary-localedata-en-ie.utf-8', 'nativesdk-glibc-binary-localedata-en-nz.utf-8', 'nativesdk-glibc-binary-localedata-en-ph.utf-8', 'nativesdk-glibc-binary-localedata-en-sc.utf-8', 'nativesdk-glibc-binary-localedata-en-sg.utf-8', 'nativesdk-glibc-binary-localedata-en-us.utf-8', 'nativesdk-glibc-binary-localedata-en-za.utf-8', 'nativesdk-glibc-binary-localedata-en-zw.utf-8', 'nativesdk-glibc-binary-localedata-es-ar.utf-8', 'nativesdk-glibc-binary-localedata-es-bo.utf-8', 'nativesdk-glibc-binary-localedata-es-cl.utf-8', 'nativesdk-glibc-binary-localedata-es-co.utf-8', 'nativesdk-glibc-binary-localedata-es-cr.utf-8', 'nativesdk-glibc-binary-localedata-es-do.utf-8', 'nativesdk-glibc-binary-localedata-es-ec.utf-8', 'nativesdk-glibc-binary-localedata-es-es.utf-8', 'nativesdk-glibc-binary-localedata-es-gt.utf-8', 'nativesdk-glibc-binary-localedata-es-hn.utf-8', 'nativesdk-glibc-binary-localedata-es-mx.utf-8', 'nativesdk-glibc-binary-localedata-es-ni.utf-8', 'nativesdk-glibc-binary-localedata-es-pa.utf-8', 'nativesdk-glibc-binary-localedata-es-pe.utf-8', 'nativesdk-glibc-binary-localedata-es-pr.utf-8', 'nativesdk-glibc-binary-localedata-es-py.utf-8', 'nativesdk-glibc-binary-localedata-es-sv.utf-8', 'nativesdk-glibc-binary-localedata-es-us.utf-8', 'nativesdk-glibc-binary-localedata-es-uy.utf-8', 'nativesdk-glibc-binary-localedata-es-ve.utf-8', 'nativesdk-glibc-binary-localedata-et-ee.utf-8', 'nativesdk-glibc-binary-localedata-eu-es.utf-8', 'nativesdk-glibc-binary-localedata-fi-fi.utf-8', 'nativesdk-glibc-binary-localedata-fo-fo.utf-8', 'nativesdk-glibc-binary-localedata-fr-be.utf-8', 'nativesdk-glibc-binary-localedata-fr-ca.utf-8', 'nativesdk-glibc-binary-localedata-fr-ch.utf-8', 'nativesdk-glibc-binary-localedata-fr-fr.utf-8', 'nativesdk-glibc-binary-localedata-fr-lu.utf-8', 'nativesdk-glibc-binary-localedata-ga-ie.utf-8', 'nativesdk-glibc-binary-localedata-gd-gb.utf-8', 'nativesdk-glibc-binary-localedata-gl-es.utf-8', 'nativesdk-glibc-binary-localedata-gv-gb.utf-8', 'nativesdk-glibc-binary-localedata-he-il.utf-8', 'nativesdk-glibc-binary-localedata-hr-hr.utf-8', 'nativesdk-glibc-binary-localedata-hsb-de.utf-8', 'nativesdk-glibc-binary-localedata-hu-hu.utf-8', 'nativesdk-glibc-binary-localedata-id-id.utf-8', 'nativesdk-glibc-binary-localedata-is-is.utf-8', 'nativesdk-glibc-binary-localedata-it-ch.utf-8', 'nativesdk-glibc-binary-localedata-it-it.utf-8', 'nativesdk-glibc-binary-localedata-ja-jp.utf-8', 'nativesdk-glibc-binary-localedata-ka-ge.utf-8', 'nativesdk-glibc-binary-localedata-kk-kz.utf-8', 'nativesdk-glibc-binary-localedata-kl-gl.utf-8', 'nativesdk-glibc-binary-localedata-ko-kr.utf-8', 'nativesdk-glibc-binary-localedata-ku-tr.utf-8', 'nativesdk-glibc-binary-localedata-kw-gb.utf-8', 'nativesdk-glibc-binary-localedata-lg-ug.utf-8', 'nativesdk-glibc-binary-localedata-lt-lt.utf-8', 'nativesdk-glibc-binary-localedata-lv-lv.utf-8', 'nativesdk-glibc-binary-localedata-mg-mg.utf-8', 'nativesdk-glibc-binary-localedata-mi-nz.utf-8', 'nativesdk-glibc-binary-localedata-mk-mk.utf-8', 'nativesdk-glibc-binary-localedata-ms-my.utf-8', 'nativesdk-glibc-binary-localedata-mt-mt.utf-8', 'nativesdk-glibc-binary-localedata-nb-no.utf-8', 'nativesdk-glibc-binary-localedata-nl-be.utf-8', 'nativesdk-glibc-binary-localedata-nl-nl.utf-8', 'nativesdk-glibc-binary-localedata-nn-no.utf-8', 'nativesdk-glibc-binary-localedata-oc-fr.utf-8', 'nativesdk-glibc-binary-localedata-om-ke.utf-8', 'nativesdk-glibc-binary-localedata-pl-pl.utf-8', 'nativesdk-glibc-binary-localedata-pt-br.utf-8', 'nativesdk-glibc-binary-localedata-pt-pt.utf-8', 'nativesdk-glibc-binary-localedata-ro-ro.utf-8', 'nativesdk-glibc-binary-localedata-ru-ru.utf-8', 'nativesdk-glibc-binary-localedata-ru-ua.utf-8', 'nativesdk-glibc-binary-localedata-sk-sk.utf-8', 'nativesdk-glibc-binary-localedata-sl-si.utf-8', 'nativesdk-glibc-binary-localedata-so-dj.utf-8', 'nativesdk-glibc-binary-localedata-so-ke.utf-8', 'nativesdk-glibc-binary-localedata-so-so.utf-8', 'nativesdk-glibc-binary-localedata-sq-al.utf-8', 'nativesdk-glibc-binary-localedata-st-za.utf-8', 'nativesdk-glibc-binary-localedata-sv-fi.utf-8', 'nativesdk-glibc-binary-localedata-sv-se.utf-8', 'nativesdk-glibc-binary-localedata-tcy-in.utf-8', 'nativesdk-glibc-binary-localedata-tg-tj.utf-8', 'nativesdk-glibc-binary-localedata-th-th.utf-8', 'nativesdk-glibc-binary-localedata-tl-ph.utf-8', 'nativesdk-glibc-binary-localedata-tr-cy.utf-8', 'nativesdk-glibc-binary-localedata-tr-tr.utf-8', 'nativesdk-glibc-binary-localedata-uk-ua.utf-8', 'nativesdk-glibc-binary-localedata-uz-uz.utf-8', 'nativesdk-glibc-binary-localedata-wa-be.utf-8', 'nativesdk-glibc-binary-localedata-xh-za.utf-8', 'nativesdk-glibc-binary-localedata-yi-us.utf-8', 'nativesdk-glibc-binary-localedata-zh-cn.utf-8', 'nativesdk-glibc-binary-localedata-zh-hk.utf-8', 'nativesdk-glibc-binary-localedata-zh-sg.utf-8', 'nativesdk-glibc-binary-localedata-zh-tw.utf-8', 'nativesdk-glibc-binary-localedata-zu-za.utf-8']' returned 100:
2) W: chown to _apt:root of directory /home/mudherp/imx-yocto-bsp/build-xwayland/tmp/work/imx8mmevk-poky-linux/core-image-minimal/1.0-r0/recipe-sysroot-native/var/cache/apt/archives/partial failed - SetupAPTPartialDirectory (1: Operation not permitted)
W: chown to root:adm of file /home/mudherp/imx-yocto-bsp/build-xwayland/tmp/work/imx8mmevk-poky-linux/core-image-minimal/1.0-r0/recipe-sysroot-native/var/log/apt/term.log failed - OpenLog (1: Operation not permitted)
mudherp
Also I am trying to populate the SDK for the core-image-minimal build AND IT IS FAILED
I am using the following commands
DISTRO=fsl-imx-xwayland MACHINE=imx8mmevk bitbake core-image-minimal -c populate_sdk
I have attached a log of the issues.
PLEASE CAN WE GET SUPPORT ON THIS ISSUE; HENCE WE ARE ON A CRITICAL TMIE-LINE
