i.MX 6ULL// Use UART2 In OP-TEE only
4,197件の閲覧回数
Karun
I'm working in i.MX 6ULL.
I need to do same thing like this : https://github.com/OP-TEE/optee_os/issues/2438#2438
UART1 is used for OP-TEE debug log.
I want to use UART2 in OP-TEE.
For that I have done the changes as mentioned in that issue.
Changes are as below.
in uboot:
file: imx-linux-kirkstone/build_secure/workspace/sources/u-boot-imx/board/freescale/mx6ullevk/mx6ullevk.c
static iomux_v3_cfg_t const uart2_pads[] = {
MX6_PAD_UART2_TX_DATA__UART2_DTE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
MX6_PAD_UART2_RX_DATA__UART2_DTE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
MX6_PAD_UART2_RTS_B__UART2_DTE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL),
MX6_PAD_UART2_CTS_B__UART2_DTE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL),
static void setup_iomux_uart(void)
setup_dtemode_uart();
imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads));
In Kernel
Disabled UART2 from linux kernel:
file: arch/arm/boot/dts/imx6ul-14x14-evk.dtsi
&uart2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart2>;
uart-has-rtscts;
/* for DTE mode, add below change /
 fsl,dte-mode; /
 pinctrl-0 = <&pinctrl_uart2dte>; */
status = "disabled";
file: drivers/clk/imx/clk-imx6ul.c
static int const clks_init_on[] __initconst = {
IMX6UL_CLK_AIPSTZ1, IMX6UL_CLK_AIPSTZ2, IMX6UL_CLK_AIPSTZ3,
IMX6UL_CLK_AXI, IMX6UL_CLK_ARM, IMX6UL_CLK_ROM,
IMX6UL_CLK_MMDC_P0_FAST, IMX6UL_CLK_MMDC_P0_IPG,
IMX6UL_CLK_OCOTP, IMX6UL_CLK_UART2_IPG, IMX6UL_CLK_UART2_SERIAL};
in imx-optee-os
file: optee/imx-optee-os/core/arch/arm/plat-imx/main.c
register_phys_mem_pgdir(MEM_AREA_IO_SEC, UART2_BASE, CORE_MMU_PGDIR_SIZE);
attached pta : core/pta/imx/uart_demo.c/
attached Host app: host_uart_demo.c
Getting below error:
# ./optee_uart
TEEC Init success: 0x0D/TC:? 0 tee_ta_init_pseudo_ta_session:296 Lookup pseudo TA aabbccdd-1122-3344-5566-778899aabbcc
D/TC:? 0 tee_ta_init_pseudo_ta_session:309 Open pta_uart2_demo
D/TC:? 0 tee_ta_init_pseudo_ta_session:326 pta_uart2_demo : aabbccdd-1122-3344-5566-778899aabbcc
OpenSession success: 0x0I/TC: >>> UART base=21e8000
D/TC:? 0 init_uart2:32 uart2_va = 0x80de8000
E/TC:? 0 init_uart2:42 >>> UART mapped!
D/TC:? 0 init_uart2:47 uart2_data.base.pa = 0x21e8000
D/TC:? 0 init_uart2:48 uart2_data.base.va = 0x80de8000
E/TC:? 0 init_uart2:56 >>> UART init!
I/TC: >>> UART va = 0x80de8000, ops = 0x840a845c
I/TC: PTA_CMD_UART_PUTC
I/TC: >>> UART SR = 0x4008
I/TC: >>> ops = 0x840a845c, putc = 0x84064fdd
[ 139.214962] 8<--- cut here ---
[ 139.218056] Unhandled fault: imprecise external abort (0x1c06) at 0x004b3194
[ 139.225117] pgd = 64e0aac0
[ 139.227836] [004b3194] *pgd=862e5835, *pte=881b575f, *ppte=881b5c7f
[ 139.234138] Internal error: : 1c06 [#1 ] SMP ARM
[ 139.238678] Modules linked in:
[ 139.241741] CPU: 0 PID: 429 Comm: optee_uart Not tainted 5.15.71-00006-g53c88ccf1338-dirty #27
[ 139.250364] Hardware name: Freescale i.MX6 Ultralite (Device Tree)
[ 139.256549] PC is at __arm_smccc_smc+0x10/0x3c
[ 139.261011] LR is at optee_smccc_smc+0x3c/0x44
[ 139.265470] pc : [] lr : [] psr: 60080013
[ 139.271740] sp : c3c9bd80 ip : c3c9bd90 fp : ffff0004
[ 139.276971] r10: c0f76f2c r9 : c3c9bdec r8 : c38cd310
[ 139.282202] r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
[ 139.288733] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 00000000
[ 139.295268] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 139.302413] Control: 10c5387d Table: 839cc06a DAC: 00000051
[ 139.308164] Register r0 information: NULL pointer
[ 139.312882] Register r1 information: NULL pointer
[ 139.317595] Register r2 information: NULL pointer
[ 139.322305] Register r3 information: NULL pointer
[ 139.327017] Register r4 information: NULL pointer
[ 139.331730] Register r5 information: NULL pointer
[ 139.336441] Register r6 information: NULL pointer
[ 139.341153] Register r7 information: NULL pointer
[ 139.345865] Register r8 information: slab kmalloc-192 start c38cd300 pointer offset 16 size 192
[ 139.354601] Register r9 information: non-slab/vmalloc memory
[ 139.360269] Register r10 information: non-slab/vmalloc memory
[ 139.366025] Register r11 information: non-paged memory
[ 139.371175] Register r12 information: non-slab/vmalloc memory
[ 139.376928] Process optee_uart (pid: 429, stack limit = 0x9e99b3d7)
[ 139.383205] Stack: (0xc3c9bd80 to 0xc3c9c000)
[ 139.387576] bd80: c1f2e4c0 c38cd300 c3c9bddc c3a3e280 00000000 00000000 00000000 00000000
[ 139.395765] bda0: c3c9bddc 00000000 ffff0004 c0f77ecc 00000000 00000000 00000000 00000000
[ 139.403951] bdc0: c3c9bddc 00000000 c38cd324 c3c9a000 00000000 00000000 00000000 ffff0004
[ 139.412138] bde0: 00000000 00000000 00000000 c38cd324 c38cd324 00000000 00000000 c3c9bdfc
[ 139.420324] be00: c3c9bdfc 32000003 00000000 00000000 00000000 00000000 00000000 00000000
[ 139.428511] be20: 00000000 26cdbbcd c3c9be54 c3a3e300 c3c9bec0 c3a3e280 c62e2b00 c3a3e2c0
[ 139.436697] be40: 00000000 bec26b58 00000000 c0f784d4 00000000 c269e000 8269e000 26cdbbcd
[ 139.444884] be60: 00000051 00000000 00000000 c62e2b00 bec26b40 c3a3e280 c3c9bec0 c0f75a20
[ 139.453072] be80: 00000000 00000000 00000000 c3c9be8c c3c9be8c 26cdbbcd 00000019 c24da600
[ 139.461259] bea0: bec26b40 00000000 00000098 00000000 c2726d00 c039e9a4 00000004 00000000
[ 139.469445] bec0: 00000000 00000001 00000000 00000000 00000000 00000004 00000000 c27500c0
[ 139.477631] bee0: c3c9bf80 00000019 00000019 00000000 00000000 00000004 bec26bb7 26cdbbcd
[ 139.485820] bf00: 00000019 8010a403 c39e2a80 bec26ac0 bec26ab0 c39e2a80 00000003 c3ee23c8
[ 139.494006] bf20: 00000000 c04dea94 00000000 00000000 c27500c0 00000000 00000000 00000000
[ 139.502194] bf40: 00000000 00000000 00000000 00000000 00000000 00000000 00000019 26cdbbcd
[ 139.510380] bf60: 004b2190 c27500c0 c27500c0 00000000 00000000 c0300324 c3c9a000 26cdbbcd
[ 139.518567] bf80: 00000000 bec26c38 00000000 bec26ac0 00000036 c0300324 c3c9a000 00000036
[ 139.526754] bfa0: 00000000 c03000c0 bec26c38 00000000 00000003 8010a403 bec26ab0 bec26aa0
[ 139.534941] bfc0: bec26c38 00000000 bec26ac0 00000036 00000000 bec26ab0 bec26b58 00000000
[ 139.543128] bfe0: 00000036 bec26a88 b6ed8269 b6e51ae6 60080030 00000003 00000000 00000000
[ 139.551319] [] (__arm_smccc_smc) from [] (optee_smccc_smc+0x3c/0x44)
[ 139.559438] [] (optee_smccc_smc) from [] (optee_do_call_with_arg+0x11c/0x2ec)
[ 139.568338] [] (optee_do_call_with_arg) from [] (optee_invoke_func+0x10c/0x188)
[ 139.577408] [] (optee_invoke_func) from [] (tee_ioctl+0xfec/0x1140)
[ 139.585434] [] (tee_ioctl) from [] (sys_ioctl+0x570/0xca8)
[ 139.592684] [] (sys_ioctl) from [] (ret_fast_syscall+0x0/0x58)
[ 139.600278] Exception stack(0xc3c9bfa8 to 0xc3c9bff0)
[ 139.605340] bfa0: bec26c38 00000000 00000003 8010a403 bec26ab0 bec26aa0
[ 139.613527] bfc0: bec26c38 00000000 bec26ac0 00000036 00000000 bec26ab0 bec26b58 00000000
[ 139.621711] bfe0: 00000036 bec26a88 b6ed8269 b6e51ae6
[ 139.626777] Code: e1a0c00d e92d00f0 e89c00f0 e1600070 (e59d4024)
[ 139.632880] ---[ end trace a7195b6f43be961b ]---
Segmentation fault
attached Full boot log: optee-log.txt
May I know what I'm missing?
タグ(2)
7 返答(返信)
3,645件の閲覧回数
Karun
@ha and nxp team
any update for us ,
we are stuck in this issue
we have found some old ways , but that are not applicable on new uboot and kernel source
so please provide us the solution for the  issue we are getting.
4,052件の閲覧回数
Harvey021
can try to copy another UART2 driver in PTA and use a specific log function in the PTA.
Harvey
4,127件の閲覧回数
Karun
To clarify my use case: I need to keep UART1 as-is, since it's being used as the debug UART.
In addition, I want to use UART2 for a different purpose, specifically within a separate PTA.
So both UART1 and UART2 will be active in OP-TEE:
UART1 → as debug console
UART2 → used by my custom PTA, my PTA communicating over UART2.
I followed the approach described in #2438 to enable UART2, but I encountered an error during runtime.
4,075件の閲覧回数
Karun
The issue is still unresolved, and I haven’t received any response yet.
4,068件の閲覧回数
Harvey021
Hi @Karun
I'm working on the issue, Will revert back to you soon, sorry for the delay.
Harvey
3,522件の閲覧回数
Karun
Hello @Harvey021 ,
any update for us ?
please let us know any steps and solution to proceed further
3,713件の閲覧回数
Karun
Hello @Harvey021 ,
any update for us ,
Latest observation ,
- we are starting microcom with 115200 baudrate in background and then doing uart communication using optee example , so that thing works.
- uart2 clocks are not by default started and when we start microcom then and then only it is getting started ,
we have checked in /sys/kernel/debug/clk/clk_summary
so seems like clock is managed by kernel driver itself.
So how can we totally configure uart with clocks to access it securely ?
%3CLINGO-SUB%20id%3D%22lingo-sub-2124807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%206ULL%2F%2F%20UART2%E3%82%92OP-TEE%E3%81%A7%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFi.MX%206ULL%E3%81%A7%E5%83%8D%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A8%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FOP-TEE%2Foptee_os%2Fissues%2F2438%232438%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FOP-TEE%2Foptee_os%2Fissues%2F2438%232438%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EUART1%20%E3%81%AF%20OP-TEE%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%AD%E3%82%B0%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EOP-TEE%E3%81%A7UART2%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%AE%E5%8F%B7%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3Euboot%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20imx-linux-kirkstone%2Fbuild_secure%2Fworkspace%2Fsources%2Fu-boot-imx%2Fboard%2Ffreescale%2Fmx6ullevk%2Fmx6ullevk.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84iomux_v3_cfg_t%20const%20uart2_pads%5B%5D%20%3D%20%7B%3CBR%20%2F%3E%20MX6_PAD_UART2_TX_DATA__UART2_DTE_RX%20%7C%20MUX_PAD_CTRL(UART_PAD_CTRL)%E3%80%81%3CBR%20%2F%3E%20MX6_PAD_UART2_RX_DATA__UART2_DTE_TX%20%7C%20MUX_PAD_CTRL(UART_PAD_CTRL)%E3%80%81%3CBR%20%2F%3E%20MX6_PAD_UART2_RTS_B__UART2_DTE_CTS%20%7C%20MUX_PAD_CTRL(UART_PAD_CTRL)%E3%80%81%3CBR%20%2F%3E%20MX6_PAD_UART2_CTS_B__UART2_DTE_RTS%20%7C%20MUX_PAD_CTRL(UART_PAD_CTRL)%E3%80%81%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84void%20setup_iomux_uart(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89UART()%3B%3CBR%20%2F%3E%20imx_iomux_v3_setup_multiple_pads(uart1_pads%E3%80%81ARRAY_SIZE(uart1_pads))%3B%3CBR%20%2F%3E%20imx_iomux_v3_setup_multiple_pads(uart2_pads%E3%80%81ARRAY_SIZE(uart2_pads))%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%86%85%3C%2FSTRONG%3E%3CBR%20%2F%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8B%E3%82%89UART2%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20arch%2FArm%2Fboot%2Fdts%2Fimx6ul-14x14-evk.dtsi%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26amp%3Buart2%20%7B%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart2%26gt%3B%3B%3CBR%20%2F%3E%20uart-has-rtscts%3B%3CBR%20%2F%3E%20%2F*%20DTE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E8%BF%BD%E5%8A%A0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3E%2F%3CBR%20%2F%3E%20%2F%3C%2FEM%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Efsl%E3%80%81dte%20%E3%83%A2%E3%83%BC%E3%83%89%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3E%2F%3CBR%20%2F%3E%20%2F%3C%2FEM%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart2dte%26gt%3B%3B%20*%2F%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E7%84%A1%E5%8A%B9%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fclk%2Fimx%2Fclk-imx6ul.c%3C%2FSTRONG%3E%3CBR%20%2F%3E%E9%9D%99%E7%9A%84int%20const%20clks_init_on%5B%5D%20__initconst%20%3D%20%7B%3CBR%20%2F%3E%20IMX6UL_CLK_AIPSTZ1%E3%80%81IMX6UL_CLK_AIPSTZ2%E3%80%81IMX6UL_CLK_AIPSTZ3%E3%80%81%3CBR%20%2F%3E%20IMX6UL_CLK_AXI%E3%80%81IMX6UL_CLK_ARM%E3%80%81IMX6UL_CLK_ROM%E3%80%81%3CBR%20%2F%3E%20IMX6UL_CLK_MMDC_P0_FAST%E3%80%81IMX6UL_CLK_MMDC_P0_IPG%E3%80%81%3CBR%20%2F%3E%20IMX6UL_CLK_OCOTP%E3%80%81IMX6UL_CLK_UART2_IPG%E3%80%81IMX6UL_CLK_UART2_SERIAL%7D%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3Eimx-optee-os%E5%86%85%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20optee%2Fimx-optee-os%2Fcore%2Farch%2Farm%2Fplat-imx%2Fmain.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eregister_phys_mem_pgdir(MEM_AREA_IO_SEC%E3%80%81UART2_BASE%E3%80%81CORE_MMU_PGDIR_SIZE)%3B%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AEPTA%3A%20core%2Fpta%2Fimx%2Fuart_demo.c%2F%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%9B%E3%82%B9%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%9B%E3%82%B9%E3%83%88_uart_%E3%83%87%E3%83%A2.c%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%20%23%20.%2Foptee_uart%3CBR%20%2F%3ETEEC%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%88%90%E5%8A%9F%3A%200x0D%2FTC%3A%3F0%20tee_ta_init_pseudo_ta_session%3A296%20%E3%83%AB%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E7%96%91%E4%BC%BC%20TA%20aabbccdd-1122-3344-5566-778899aabbcc%3C%2FP%3E%3CP%3ED%2FTC%3A%3F%200%20tee_ta_init_pseudo_ta_session%3A309%20pta_uart2_demo%20%E3%82%92%E9%96%8B%E3%81%8F%3CBR%20%2F%3ED%2FTC%3A%3F0%20tee_ta_init_pseudo_ta_session%3A326%20pta_uart2_demo%3A%20aabbccdd-1122-3344-5566-778899aabbcc%3CBR%20%2F%3E%20OpenSession%20%E6%88%90%E5%8A%9F%3A%200x0I%2FTC%3A%20%26gt%3B%26gt%3B%26gt%3B%20UART%20%E3%83%99%E3%83%BC%E3%82%B9%20%3D%2021e8000%3C%2FP%3E%3CP%3ED%2FTC%3A%3F%200%20init_uart2%3A32%20uart2_va%20%3D%200x80de8000%3CBR%20%2F%3E%E7%AD%89%EF%BC%9A%EF%BC%9F0%20init_uart2%3A42%20%26gt%3B%26gt%3B%26gt%3B%20UART%20%E3%81%8C%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F!%3CBR%20%2F%3E%20D%2FTC%3A%3F0%20init_uart2%3A47%20uart2_data.base.pa%20%3D%200x21e8000%3CBR%20%2F%3E%20D%2FTC%3A%3F0%20init_uart2%3A48%20uart2_data.base.va%20%3D%200x80de8000%3CBR%20%2F%3E%E7%AD%89%EF%BC%9A%EF%BC%9F0%20init_uart2%3A56%20%26gt%3B%26gt%3B%26gt%3B%20UART%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!%3CBR%20%2F%3EI%2FTC%3A%20%26gt%3B%26gt%3B%26gt%3B%20UART%20va%20%3D%200x80de8000%E3%80%81ops%20%3D%200x840a845c%3CBR%20%2F%3E%20I%2FTC%3A%20PTA_CMD_UART_PUTC%3CBR%20%2F%3E%20I%2FTC%3A%20%26gt%3B%26gt%3B%26gt%3B%20UART%20SR%20%3D%200x4008%3CBR%20%2F%3E%20I%2FTC%3A%20%26gt%3B%26gt%3B%26gt%3B%20ops%20%3D%200x840a845c%E3%80%81putc%20%3D%200x84064fdd%3CBR%20%2F%3E%20%5B%20139.214962%5D%208%26lt%3B---%20%E3%81%93%E3%81%93%E3%81%A7%E3%82%AB%E3%83%83%E3%83%88%20---%3CBR%20%2F%3E%20%5B%20139.218056%5D%20%E6%9C%AA%E5%87%A6%E7%90%86%E3%81%AE%E9%9A%9C%E5%AE%B3%3A%200x004b3194%20%E3%81%A7%E4%B8%8D%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%A4%96%E9%83%A8%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%88%20(0x1c06)%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%20139.225117%5D%20pgd%20%3D%2064e0aac0%3CBR%20%2F%3E%20%5B%20139.227836%5D%20%5B004b3194%5D%20*pgd%3D862e5835%E3%80%81*pte%3D881b575f%E3%80%81*ppte%3D881b5c7f%3CBR%20%2F%3E%20%5B%20139.234138%5D%20%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%3A%201c06%20%5B%231%20%5D%20SMP%20ARM%3CBR%20%2F%3E%20%5B%20139.238678%5D%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%3CBR%20%2F%3E%20%5B%20139.241741%5D%20CPU%3A%200%20PID%3A%20429%20%E9%80%9A%E4%BF%A1%3A%20optee_uart%20%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%205.15.71-00006-g53c88ccf1338-dirty%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8327%3CBR%20%2F%3E%20%5B%20139.250364%5D%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%90%8D%3A%20Freescale%20i.MX6%20Ultralite%20(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC)%3CBR%20%2F%3E%20%5B%20139.256549%5D%20PC%E3%81%AF__arm_smccc_smc%2B0x10%2F0x3c%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20139.261011%5D%20LR%E3%81%AFoptee_smccc_smc%2B0x3c%2F0x44%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20139.265470%5D%20pc%20%3A%20%5B%5D%20lr%20%3A%20%5B%5D%20psr%3A%2060080013%3CBR%20%2F%3E%20%5B%20139.271740%5D%20sp%20%3A%20c3c9bd80%20ip%20%3A%20c3c9bd90%20fp%20%3A%20ffff0004%3CBR%20%2F%3E%20%5B%20139.276971%5D%20r10%3A%20c0f76f2c%20r9%3A%20c3c9bdec%20r8%3A%20c38cd310%3CBR%20%2F%3E%20%5B%20139.282202%5D%20r7%20%3A%2000000000%20r6%20%3A%2000000000%20r5%20%3A%2000000000%20r4%20%3A%2000000000%3CBR%20%2F%3E%20%5B%20139.288733%5D%20r3%20%3A%2000000000%20r2%20%3A%2000000000%20r1%20%3A%2000000000%20r0%20%3A%2000000000%3CBR%20%2F%3E%20%5B%20139.295268%5D%20%E3%83%95%E3%83%A9%E3%82%B0%3A%20nZCv%20IRQ%20%E3%82%AA%E3%83%B3%20FIQ%20%E3%82%AA%E3%83%B3%20%E3%83%A2%E3%83%BC%E3%83%89%20SVC_32%20ISA%20ARM%20%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%20%E3%81%AA%E3%81%97%3CBR%20%2F%3E%5B%20139.302413%5D%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%3A%2010c5387d%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%20839cc06a%20DAC%3A%2000000051%3CBR%20%2F%3E%20%5B%20139.308164%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20r0%20%E6%83%85%E5%A0%B1%3A%20NULL%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.312882%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFr1%E6%83%85%E5%A0%B1%3A%20NULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.317595%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFr2%E6%83%85%E5%A0%B1%3A%20NULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.322305%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFr3%E6%83%85%E5%A0%B1%3A%20NULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.327017%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFr4%E6%83%85%E5%A0%B1%3A%20NULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.331730%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFr5%E6%83%85%E5%A0%B1%3A%20NULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.336441%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFr6%E6%83%85%E5%A0%B1%3A%20NULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.341153%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20r7%20%E6%83%85%E5%A0%B1%3A%20NULL%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%3CBR%20%2F%3E%5B%20139.345865%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20r8%20%E6%83%85%E5%A0%B1%3A%20%E3%82%B9%E3%83%A9%E3%83%96%20kmalloc-192%20%E9%96%8B%E5%A7%8B%20c38cd300%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%2016%20%E3%82%B5%E3%82%A4%E3%82%BA%20192%3CBR%20%2F%3E%20%5B%20139.354601%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20r9%20%E6%83%85%E5%A0%B1%3A%20%E9%9D%9E%E3%82%B9%E3%83%A9%E3%83%96%2Fvmalloc%20%E3%83%A1%E3%83%A2%E3%83%AA%3CBR%20%2F%3E%5B%20139.360269%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20r10%20%E6%83%85%E5%A0%B1%3A%20%E9%9D%9E%E3%82%B9%E3%83%A9%E3%83%96%2Fvmalloc%20%E3%83%A1%E3%83%A2%E3%83%AA%3CBR%20%2F%3E%5B%20139.366025%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20r11%20%E6%83%85%E5%A0%B1%3A%20%E9%9D%9E%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%A2%E3%83%AA%3CBR%20%2F%3E%5B%20139.371175%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20r12%20%E6%83%85%E5%A0%B1%3A%20%E9%9D%9E%E3%82%B9%E3%83%A9%E3%83%96%2Fvmalloc%20%E3%83%A1%E3%83%A2%E3%83%AA%3CBR%20%2F%3E%5B%20139.376928%5D%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20optee_uart%20(pid%3A%20429%E3%80%81%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E5%88%B6%E9%99%90%20%3D%200x9e99b3d7)%3CBR%20%2F%3E%20%5B%20139.383205%5D%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3A%20(0xc3c9bd80%20%E3%81%8B%E3%82%89%200xc3c9c000)%3CBR%20%2F%3E%20%5B%20139.387576%5D%20bd80%3A%20c1f2e4c0%20c38cd300%20c3c9bddc%20c3a3e280%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B%20139.395765%5D%20bda0%3A%20c3c9bddc%2000000000%20ffff0004%20c0f77ecc%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B%20139.403951%5D%20bdc0%3A%20c3c9bddc%2000000000%20c38cd324%20c3c9a000%2000000000%2000000000%2000000000%20ffff0004%3CBR%20%2F%3E%20%5B%20139.412138%5D%20bde0%3A%2000000000%2000000000%2000000000%20c38cd324%20c38cd324%2000000000%2000000000%20c3c9bdfc%3CBR%20%2F%3E%20%5B%20139.420324%5D%20be00%3A%20c3c9bdfc%2032000003%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B%20139.428511%5D%20be20%3A%2000000000%2026cdbbcd%20c3c9be54%20c3a3e300%20c3c9bec0%20c3a3e280%20c62e2b00%20c3a3e2c0%3CBR%20%2F%3E%20%5B%20139.436697%5D%20be40%3A%2000000000%20bec26b58%2000000000%20c0f784d4%2000000000%20c269e000%208269e000%2026cdbbcd%3CBR%20%2F%3E%20%5B%20139.444884%5D%20be60%3A%2000000051%2000000000%2000000000%20c62e2b00%20bec26b40%20c3a3e280%20c3c9bec0%20c0f75a20%3CBR%20%2F%3E%20%5B%20139.453072%5D%20be80%3A%2000000000%2000000000%2000000000%20c3c9be8c%20c3c9be8c%2026cdbbcd%2000000019%20c24da600%3CBR%20%2F%3E%20%5B%20139.461259%5D%20bea0%3A%20bec26b40%2000000000%2000000098%2000000000%20c2726d00%20c039e9a4%2000000004%2000000000%3CBR%20%2F%3E%20%5B%20139.469445%5D%20bec0%3A%2000000000%2000000001%20000000000%2000000000%2000000004%2000000000%20c27500c0%3CBR%20%2F%3E%20%5B%20139.477631%5D%20bee0%3A%20c3c9bf80%2000000019%20000000019%2000000000%2000000000%2000000004%20bec26bb7%2026cdbbcd%3CBR%20%2F%3E%20%5B%20139.485820%5D%20bf00%3A%2000000019%208010a403%20c39e2a80%20bec26ac0%20bec26ab0%20c39e2a80%2000000003%20c3ee23c8%3CBR%20%2F%3E%20%5B%20139.494006%5D%20bf20%3A%2000000000%20c04dea94%2000000000%2000000000%20c27500c0%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B%20139.502194%5D%20bf40%3A%2000000000%2000000000%2000000000%2000000000%200000000%2000000019%2026cdbbcd%3CBR%20%2F%3E%20%5B%20139.510380%5D%20bf60%3A%20004b2190%20c27500c0%20c27500c0%2000000000%2000000000%20c0300324%20c3c9a000%2026cdbbcd%3CBR%20%2F%3E%20%5B%20139.518567%5D%20bf80%3A%2000000000%20bec26c38%2000000000%20bec26ac0%2000000036%20c0300324%20c3c9a000%2000000036%3CBR%20%2F%3E%20%5B%20139.526754%5D%20bfa0%3A%2000000000%20c03000c0%20bec26c38%2000000000%2000000003%208010a403%20bec26ab0%20bec26aa0%3CBR%20%2F%3E%20%5B%20139.534941%5D%20bfc0%3A%20bec26c38%2000000000%20bec26ac0%2000000036%2000000000%20bec26ab0%20bec26b58%2000000000%3CBR%20%2F%3E%20%5B%20139.543128%5D%20bfe0%3A%2000000036%20bec26a88%20b6ed8269%20b6e51ae6%2060080030%20000000003%20000000000%2000000000%3CBR%20%2F%3E%20%5B%20139.551319%5D%20%5B%5D%20(__arm_smccc_smc)%20%E3%81%8B%E3%82%89%20%5B%5D%20(optee_smccc_smc%2B0x3c%2F0x44)%3CBR%20%2F%3E%20%5B%20139.559438%5D%20%5B%5D%20(optee_smccc_smc)%20%E3%81%8B%E3%82%89%20%5B%5D%20(optee_do_call_with_arg%2B0x11c%2F0x2ec)%3CBR%20%2F%3E%20%5B%20139.568338%5D%20%5B%5D%20(optee_do_call_with_arg)%20%E3%81%8B%E3%82%89%20%5B%5D%20(optee_invoke_func%2B0x10c%2F0x188)%3CBR%20%2F%3E%20%5B%20139.577408%5D%20%5B%5D%20(optee_invoke_func)%20%E3%81%8B%E3%82%89%20%5B%5D%20(tee_ioctl%2B0xfec%2F0x1140)%3CBR%20%2F%3E%20%5B%20139.585434%5D%20%5B%5D%20(tee_ioctl)%20%E3%81%8B%E3%82%89%20%5B%5D%20(sys_ioctl%2B0x570%2F0xca8)%3CBR%20%2F%3E%20%5B%20139.592684%5D%20%5B%5D%20(sys_ioctl)%20%E3%81%8B%E3%82%89%20%5B%5D%20(ret_fast_syscall%2B0x0%2F0x58)%3CBR%20%2F%3E%20%5B%20139.600278%5D%20%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xc3c9bfa8%20%E3%81%8B%E3%82%89%200xc3c9bff0)%3CBR%20%2F%3E%20%5B%20139.605340%5D%20bfa0%3A%20bec26c38%2000000000%2000000003%208010a403%20bec26ab0%20bec26aa0%3CBR%20%2F%3E%20%5B%20139.613527%5D%20bfc0%3A%20bec26c38%2000000000%20bec26ac0%2000000036%2000000000%20bec26ab0%20bec26b58%2000000000%3CBR%20%2F%3E%20%5B%20139.621711%5D%20bfe0%3A%2000000036%20bec26a88%20b6ed8269%20b6e51ae6%3CBR%20%2F%3E%20%5B%20139.626777%5D%20%E3%82%B3%E3%83%BC%E3%83%89%3A%20e1a0c00d%20e92d00f0%20e89c00f0%20e1600070%20%EF%BC%88e59d4024%EF%BC%89%3CBR%20%2F%3E%20%5B%20139.632880%5D%20---%5B%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E7%B5%82%E4%BA%86%20a7195b6f43be961b%20%5D---%3CBR%20%2F%3E%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%81%95%E5%8F%8D%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eoptee-log.txt%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8C%E8%B6%B3%E3%82%8A%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%206ULL%2F%2F%20Use%20UART2%20In%20OP-TEE%20only%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192970%22%20target%3D%22_blank%22%3E%40Harvey021%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%95%E3%81%8B%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E9%80%B2%E3%82%80%E3%81%9F%E3%82%81%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A8%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%206ULL%2F%2F%20Use%20UART2%20In%20OP-TEE%20only%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F155811%22%20target%3D%22_blank%22%3E%40ha%3C%2FA%3E%E3%81%A8nxp%E3%83%81%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%95%E3%81%8B%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E8%A1%8C%E3%81%8D%E8%A9%B0%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%3CBR%20%2F%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%8F%A4%E3%81%84%E6%96%B9%E6%B3%95%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84uboot%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3ESO%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%206ULL%2F%2F%20Use%20UART2%20In%20OP-TEE%20only%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192970%22%20target%3D%22_blank%22%3E%40Harvey021%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%95%E3%81%8B%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E6%96%B0%E3%81%AE%E8%A6%B3%E6%B8%AC%E3%80%81%3C%2FP%3E%3CP%3E-%20%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%A7%20115200%20%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A7%20microcom%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81Optee%20%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20UART%20%E9%80%9A%E4%BF%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81SO%20%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20uart2%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81microcom%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%AE%E3%81%BF%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2Fsys%2Fkernel%2Fdebug%2Fclk%2Fclk_summary%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESO%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%87%AA%E4%BD%93%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%AE%A1%E7%90%86%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESO%E3%80%81UART%20%E3%82%92%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BB%98%E3%81%8D%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%81%A6%E5%AE%89%E5%85%A8%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2132239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%206ULL%2F%2F%20Use%20UART2%20In%20OP-TEE%20only%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2132239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPTA%20%E5%86%85%E3%81%AE%E5%88%A5%E3%81%AE%20UART2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81PTA%20%E5%86%85%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%AD%E3%82%B0%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2131591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%206ULL%2F%2F%20Use%20UART2%20In%20OP-TEE%20only%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224470%22%20target%3D%22_blank%22%3E%40Karun%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E8%A7%A3%E6%B1%BA%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%BE%8C%E3%81%BB%E3%81%A9%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2130899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%206ULL%2F%2F%20Use%20UART2%20In%20OP-TEE%20only%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%BE%E3%81%A0%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%81%BE%E3%81%A0%E4%BD%95%E3%81%AE%E8%BF%94%E7%AD%94%E3%82%82%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2126109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX%206ULL%2F%2F%20Use%20UART2%20In%20OP-TEE%20only%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2126109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A7%81%E3%81%AECASE%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81UART1%20%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20UART%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81UART2%20%E3%82%92%E5%88%A5%E3%81%AE%E7%9B%AE%E7%9A%84%E3%80%81%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E5%88%A5%E3%81%AE%20PTA%20%E5%86%85%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESO%E3%80%81OP-TEE%20%E3%81%A7%E3%81%AF%20UART1%20%E3%81%A8%20UART2%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20UART1%20%E2%86%92%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3EUART2%20%E2%86%92%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20PTA%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%80%81PTA%20%E3%81%AF%20UART2%20%E7%B5%8C%E7%94%B1%E3%81%A7%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EUART2%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20%232438%20%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E
