how to resize a video from high resolution to wga farmat
5,430件の閲覧回数
veeranjaneyulug
Hi ,
Every one have a great day.
Thanks for support .
i have the issue how to resize the video by using imx6 test applications any body fix this issue plz let me know.
my procedure mentioned below like this.
Hi igor,
Thanks for your guidence i solved my issue as per user guide .
I have another problem how to resize the video by using
bitbake imx-test
i run the above command it will give some imx6 related binaries generated.
in that i used mxc_ipudevtest.c test application. i used but image was not resize .
Image capturing purpose i used below command ie working .
mxc_v4l2_capture.out -iw 320 -ih 240 -ow 320 -oh 240 -m 1 -fr 15 -d /home/video0 -i 1 -c 20 /home/320_240_15fps.yuv ----> image capture
But resizing purpose i used below command but not resize and
./mxc_ipudevtest.out -C configfile outfile
but not resize .
i used gstreamer plugin also.
gst-launch
gst-inspect
plz can u explore all this to me .
Thanks and regards
ラベル(6)
4,778件の閲覧回数
document is attached in previous answer, click mouse on red:
5 返答(返信)
4,776件の閲覧回数
Hi veeranjaneyulu
seems it is not supported on i.MX6, please refer to
attached Release Notes p.10 :
IPU library is removed from i.MX 6.
4,776件の閲覧回数
veeranjaneyulug
Thanks for your reply.
Have a great day.
please can you attach Release Notes P.10 once .but in the above you mentioned that release note but not attached .so can you attach that release Note .
Then how to resize video any idea.
we used in place of imx6 ipu application .we used gstreamer plug in
video resizing we used gstreamer1.0-lnspect and gstreamer1.0-lanuch
RTSP resize on target pipeline:
./test-launch "(v4l2src ! videobox autocrop=true ! video/x-raw, width=1920, height=1080 ! videoconvert ! x264enc ! rtph264pay name=pay0 pt=96 )"
we used above command  its correct ? And how we run on target board can you give me idea.
Thanks & Regards
4,779件の閲覧回数
4,776件の閲覧回数
veeranjaneyulug
Hi igor,
Thanks for your co-operation and your reply.
yes. i saw the document.But how we resize the video size from 1920x1080 to wvga format   .how can i convert this on imx6 target board .we used imx6s/Dsabresd target .can you please give me any idea of that .
we have gstreamer-1.4.2 test applications binaries .Gst-inspect and gst-launch-1.0 this binaries will resize the video?
Thanks & Regards
4,776件の閲覧回数
Hi veeranjaneyulu
for more resize options please check attached document
sect.7.5.3 Video conversion
~igor
