how to modify code when hardware change from MMPF0100F0EP to MMPF0100F0AEP?
2,044件の閲覧回数
mingmingyuan
board:samba_sd
system:linux 3.0.35
ラベル(2)
2 返答(返信)
1,943件の閲覧回数
art
Generally, no code modification is required when migrating from MMPF0100 to
MMPF0100A part. The differences between these two parts are summarized in the Table 2
of the MMPF0100 Data Sheet Rev.12 document, available on the MMPF0100
Documentation web page:
http://www.freescale.com/products/analog-power-management/power-management/pmics/pmics-for-i.mx-proc...
Artur
1,943件の閲覧回数
mingmingyuan
I found old pmu sw4 default output is 3.15v,use the same code, new pmu sw4 output 1.8v
Can you tell me how to modify sw4 from 1.8v to 3.15v ?
