how to disable selfref on IMX8MP?
jekim
The default value of the PWRCTL register(0x3d400030) was 0x1. It was changed to 0x0 to disable selfref. The reference manual explained selfref_en that If true then the DDRC puts the SDRAM into Self Refresh after a programmable number of cycles "maximum idle clocks before Self Refresh (PWRTMG.selfref_to_x32)". This register bit may be reprogrammed during the course of normal operation. Self refresh events were still found with the selfref_en value 0x0. How to prevent reprogramming of this parameter?
Thanks.
pengyong_zhang
Hi @jekim
we do not support disabled the DRAM self-refresh feature. and why are you want to disable it? disabled it will causa date loss.
B.R
pengyong_zhang
hI @jekim
self refresh is DRAM itself feature in low power mode. And you said auto-refresh is DDRC site feature at DRAM normal mode. Both of refresh features are aim to protect the data. We do not support disabled the self refresh.
B.R
pengyong_zhang
Hi @jekim
B.R
jekim
Hi @pengyong_zhang ,
In failure analysis, enabling and disabling some features are often required.
Without self refresh, auto-refresh at tREFI period still can protect RAM data.
Self refresh is not an inevitable mode for RAM operation.
Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-2198831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ehow%20to%20disable%20selfref%20on%20IMX8MP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3EHello%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20default%20value%20of%20the%20PWRCTL%20register(0x3d400030)%20was%200x1.%20It%20was%20changed%20to%200x0%20to%20disable%20selfref.%20The%20reference%20manual%20explained%20selfref_en%20that%20If%20true%20then%20the%20DDRC%20puts%20the%20SDRAM%20into%20Self%20Refresh%20after%20a%20programmable%20number%20of%20cycles%20%22maximum%20idle%20clocks%20before%20Self%20Refresh%20(PWRTMG.selfref_to_x32)%22.%20This%20register%20bit%20may%20be%20reprogrammed%20during%20the%20course%20of%20normal%20operation.%20Self%20refresh%20events%20were%20still%20found%20with%20the%20selfref_en%20value%200x0.%20How%20to%20prevent%20reprogramming%20of%20this%20parameter%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20disable%20selfref%20on%20IMX8MP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EhI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F167418%22%20target%3D%22_blank%22%3E%40jekim%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eself%20refresh%20is%20DRAM%20itself%20feature%20in%20low%20power%20mode.%20And%20you%20said%20auto-refresh%20is%20DDRC%20site%20feature%20at%20DRAM%20normal%20mode.%20Both%20of%20refresh%20features%20are%20aim%20to%20protect%20the%20data.%20We%20do%20not%20support%20disabled%20the%20self%20refresh.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20disable%20selfref%20on%20IMX8MP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIn%20failure%20analysis%2C%20enabling%20and%20disabling%20some%20features%20are%20often%20required.%26nbsp%3B%3C%2FP%3E%3CP%3EWithout%20self%20refresh%2C%20auto-refresh%20at%20tREFI%20period%20still%20can%20protect%20RAM%20data.%26nbsp%3B%3C%2FP%3E%3CP%3ESelf%20refresh%20is%20not%20an%20inevitable%20mode%20for%20RAM%20operation.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20disable%20selfref%20on%20IMX8MP%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F167418%22%20target%3D%22_blank%22%3E%40jekim%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ewe%20do%20not%20support%20disabled%20the%20DRAM%20self-refresh%20feature.%20and%20why%20are%20you%20want%20to%20disable%20it%3F%20disabled%20it%20will%20causa%20date%20loss.%3C%2FP%3E%0A%3CP%3EB.R%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
