how to check the status of leds in imx8m mini in ANDROID 10 OS.
After booting into Android in which path or file .I can see the status of leds in android 10 OS.
And in which path or file i have configure to high or low gpio in imx8m mini evk board.
i want to connect single led in gpio pin and toggle the led for 5 min. how can i config
 Zhiming_Liu
			Zhiming_Liu
--> Same operation in linux
--> You can see this java api https://www.digi.com/resources/documentation/digidocs/embedded/android/oreo/cc6/android_r_apix-gpio
