how to check for updates
已解决
跳至解决方案
3,399 次查看
gxk
is there posiibility to check for updates for my imx27 sdk code, specialy kernel and redboot?
标签 (1)
标记 (1)
1 解答
2,930 次查看
itisravi
I don't think there is an option for auto-update.
For the kernel, there is there is an option of choosing which kernel you want to build in the ltib menu (you can provide the path to your custom kernel tree).
Building redboot from sources is explained in the documentaion.
But in anycase, i think it's better to just use the kernel and bootloader that came along with the BSP (it's tested to work on board by freescale  :smileywink: )
For other packages, you can try this
在原帖中查看解决方案
2 回复数
2,931 次查看
itisravi
2,930 次查看
gxk
thanks for answer.
