how to change system logo?
2,350件の閲覧回数
zhouzheng
I want change the system logo,so I change the dir android_system/out/target/product/XXX/system/framework/framework-res.apk,I change the picture and recreat the system.img,but when I start the board and wait system is boot finished,I clicked the Ui button(setting button),the console appear binder failed reply XXX,truncked pid xxx by signal 9,why?how to resolve it?
ラベル(2)
3 返答(返信)
1,555件の閲覧回数
harreymarchael
Last week, I wanted to change my system logo and found some helpful tips. It’s amazing how a good logo can make a big difference! If you’re thinking about a new look for your business, consider working with a local professional logo design company to create something special.
2,250件の閲覧回数
igorpadykov
Hi zhou
this is common android procedure, one can look at android forums:
http://android.stackexchange.com/questions/27762/what-exactly-is-framework-res-apk
http://www.androidtablets.net/threads/how-to-manually-replace-framework-res-apk-on-stock-roms.43716/
2,250件の閲覧回数
zhouzheng
Thanks for your answer.
But this morning I tried to use U-disk to cover the file,instead of using adb  -the initial method. When I recompiled the file system, re-powered the board, clicked on the graphics button, the board was unlimited restart. How can I fix this problem?
Zhou
