hardware compression using ffmpeg library on i.MX8MP evk
2,756 次查看
sagarmane
I'm using i.MX8MP evk with BSP 5.4.70.2.3.2, Can we achieve hardware compression with ffmpeg library available on this board?
2,751 次查看
khang_letruong
Senior Contributor III
Hi @sagarmane ,
I found the VPE plugin (used with ffmpeg) in following repositories from VeriSilicon, partner of NXP that provides Hantro VC8000D/VC8000E found in i.MX8MP :
https://github.com/VeriSilicon/vpe
https://github.com/VeriSilicon/ffmpeg
It seems that they tested on iMX8MM. I am curious about how feasible to use it on iMX8MP, too.
