gst-rtsp-server fails
2,497 次查看
dcheng
I try to add gst-rtsp-server.0.10.8 into LTIB-121218. It crashes when answering request. Since it is older than existing gst-plugins-good-0.10.30 in LTIB. Is that the reason it fails? Or simply, is there anyone can provide help to create a rtsp server for IMX6?
标签 (2)
标记 (2)
1,734 次查看
dcheng
I have found my own solution. gst-rtsp-server does work. This is what happen. I have my camera sending rtp to imx6 rtsp server. To make it work, my camera, also running gstreamer, needs to specify send-config=true for rtpmp4vpay element.
1,735 次查看
dcheng
1,734 次查看
ruiguifang
can you show me how to install the rtsp server ,and how to connect rtsp server?
