how to make stop the display at the last frame by using streamer tools
已解决
跳至解决方案
1,473 次查看
ruiguifang
I wanna switch stream from several rtsp.There was blackscreen about 3 seconds between one video to another.how to make stop the display at the last frame by using streamer tools
标签 (4)
标记 (3)
1 解答
1,330 次查看
ruiguifang
I have found the solution.the command following:
gst-launch rtspsrc location=rtsp://192.168.1.x/x  latency=0  typefind=true ! rtph264depay ! capsfilter caps="video/x-h264,width=1280,height=720,framerate=(fraction)30/1" ! vpudec  low-latency=true frame-plus=9 framedrop=false ! queue max-size-buffers=0 max-size-time=0 ! mfw_v4lsink
在原帖中查看解决方案
1 回复
1,331 次查看
ruiguifang
