git.freescale.com: Name or service not known!!
1,823 次查看
jackyl
I'm following the Android_User's_Guide.pdf of iMX6Q.SDB,
when trying to get the N7.1.2_2.0.0 kernel source code from Freescale open source git,
it says:
# git clone git://git.freescale.com/imx/linux-imx.git kernel_imx
Cloning into 'kernel_imx'...
fatal: unable to connect to git.freescale.com:
How can I do?
标签 (2)
标记 (2)
1,761 次查看
Rita_Wang
Recommend you to use the p9.0.0_2.2.0-ga verison BSP, do not use the N7.1.2_2.0.0.
1,761 次查看
Rita_Wang
Or you can try to using the  p9.0.0_2.2.0-ga this verison BSP. Any questions you can contact us.
1,761 次查看
Rita_Wang
The git://git.freescale.com repository was replaced by https://source.codeaurora.org.
For the N7.1.2_2.0.0 version BSP kernel you can try the following command to get
 git clone https://source.codeaurora.org/external/imx/linux-imx -b imx_4.1.15_2.0.0_ga
