file .config
file .config
Nico
Fresh Out Contributor
Do you know where is hte file .config?
mmaaxx
It Depends on what kind of .config you are looking for. Linux Kernel .config, usually could be found in the root of the kernel build directory :
ltib/rpm/BUILD/linux/
