failed to capture 16bit greyscale image
1,033 次查看
Ken
I try to capture 16bit greyscale image, but the result is amazying. Vsync is 50Hz, I get 100fps in fact. The data I get is in confusion.
If I set CSI's pixel width to be 8bit, it will be 50fps but the low 8bit will be lost. I also modified CPMEM to support 16bit generic transform. I don't know where is the problem. CSI? IDMAC? or both?
I try CSI's test mode but v4ls capture always reports timeout, anyone know how to use it?
标记 (2)
941 次查看
MarkoPanger
Have you solved this problem at the end ?
Marko
