ethernet phy-reset using GPIO pin
2,683件の閲覧回数
Eduardo-S-Oliveira
I'm trying to use the external ethernet but I can't configure phy-reset. As a workaround, I've implemented a shell script to toggle the phy-reset and reboot the imx93, in this condition, the ethernet is working. When I try to configure the same gpio (GPIO2_IO27) as the phy-reset in the device tree, it's not working. Measuring with an oscilloscope, I didn't see the pin toggle. What I'm doing wrong? This a part of my device tree
fecgrp {
fsl,pins = <0xf8 0x2a8 0x00 0x00 0x00 0x57e 0xfc 0x2ac 0x00 0x00 0x00 0x57e 0x100 0x2b0 0x00 0x00 0x00 0x57e 0x104 0x2b4 0x00 0x00 0x00 0x57e 0xf4 0x2a4 0x00 0x00 0x00 0x58e 0xf0 0x2a0 0x00 0x00 0x00 0x57e 0xe4 0x294 0x00 0x00 0x00 0x57e 0xe0 0x290 0x00 0x00 0x00 0x57e 0xdc 0x28c 0x00 0x00 0x00 0x57e 0xd8 0x288 0x00 0x00 0x00 0x57e 0xec 0x29c 0x00 0x00 0x00 0x58e 0xe8 0x298 0x00 0x00 0x00 0x57e 0x7c 0x22c 0x00 0x00 0x00 0x91e>;
phandle = <0x3f>;
ethernet@42890000 {
    compatible = "fsl,imx93-fec", "fsl,imx8mq-fec";
    reg = <0x42890000 0x10000>;
    interrupts = <0x00 0xb3 0x04>, <0x00 0xb4 0x04>, <0x00 0xb5 0x04>, <0x00 0xb6 0x04>;
    clocks = <0x07 0xb6>, <0x07 0xb6>, <0x07 0x5d>, <0x07 0x5f>, <0x07 0x60>;
    clock-names = "ipg", "ahb", "ptp", "enet_clk_ref", "enet_out";
    status = "okay";
    pinctrl-names = "default";
    pinctrl-0 = <0x3f>;
    phy-mode = "rgmii-id";
    phy-handle = <0x40>;
ethernet@428a0000 {
compatible = "nxp,imx93-dwmac-eqos\0snps,dwmac-5.10a";
reg = <0x428a0000 0x10000>;
interrupts = <0x00 0xb8 0x04 0x00 0xb7 0x04>;
interrupt-names = "macirq\0eth_wake_irq";
clocks = <0x07 0xb7 0x07 0xb7 0x07 0x5e 0x07 0x5c 0x07 0xb7>;
clock-names = "stmmaceth\0pclk\0ptp_ref\0tx\0mem";
assigned-clocks = <0x07 0x5e 0x07 0x5c>;
assigned-clock-parents = <0x07 0x06 0x07 0x04>;
assigned-clock-rates = <0x5f5e100 0xee6b280>;
intf_mode = <0x27 0x28>;
snps,clk-csr = <0x05>;
nvmem-cells = <0x42>;
nvmem-cell-names = "mac-address";
status = "okay";
pinctrl-0 = <0x43>;
phy-mode = "rgmii";
phy-handle = <0x44>;
phandle = <0xb3>;
mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <0x01>;
#size-cells = <0x00>;
clock-frequency = <0xf4240>;
ethernet-phy@0 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0x00>;
eee-broken-1000t;
reset-gpios = <0x13 0x07 0x01>;
reset-assert-us = <0x2710>;
reset-deassert-us = <0x186a0>;
mxl-8611x,led0_cfg = <0x2600>;
mxl-8611x,led1_cfg = <0x70>;
phandle = <0x44>;
ethernet-phy@5 {
reg = <0x05>;
reset-gpios = <0x15 0x1b 0x01>;
reset-deassert-us = <0x13880>;
phandle = <0x40>;
3 返答(返信)
2,662件の閲覧回数
Eduardo-S-Oliveira
Hi, @Chavira,
I'm using a VAR-SOM-MX93 from Variscite. I don't know exactly what BSP version is running.
I'm attaching the device tree; it's a customization from the Variscite original device tree.
2,598件の閲覧回数
Chavira
Hi @Eduardo-S-Oliveira,
After reviewing your device tree, the configuration itself looks correct; however, the PHY reset GPIO is currently configured as active‑high.
In the node ethernet-phy@5, you have:
reset-gpios = <0x15 0x1b 0x00>;
The third value (0x00) indicates GPIO_ACTIVE_HIGH, meaning the reset signal is asserted when the GPIO is driven high.
If your hardware expects the PHY reset to be active‑low, you should change this line to:
This sets the reset GPIO to GPIO_ACTIVE_LOW, so the reset is asserted when the signal is driven low.
What reset behavior are you expecting on the PHY side?
Chavira
2,672件の閲覧回数
Chavira
Thank you for contacting NXP Support!
Could you please provide the following information so we can better analyze the issue?
Which BSP version are you working with?
Would you be able to share your device tree file?
This information will help us reproduce the setup and investigate the problem more effectively.
Chavira
%3CLINGO-SUB%20id%3D%22lingo-sub-2290411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGPIO%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88PHY%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2290411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%E5%A4%96%E9%83%A8%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81phy-reset%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81phy-reset%20%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%20imx93%20%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E5%86%85%E3%81%AE%20phy-reset%20%E3%81%A8%E5%90%8C%E3%81%98%20gpio%20(GPIO2_IO27)%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%94%E3%83%B3%E3%81%AE%E3%83%88%E3%82%B0%E3%83%AB%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BD%95%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3Efecgrp%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efsl%E3%80%81%E3%83%94%E3%83%B3%20%3D%20%26lt%3B0xf8%200x2a8%200x00%200x00%200x00%200x57e%200xfc%200x2ac%200x00%200x00%200x00%200x57e%200x100%200x2b0%200x00%200x00%200x00%200x57e%200x104%200x2b4%200x00%200x00%200x00%200x57e%200xf4%200x2a4%200x00%200x00%200x00%200x58e%200xf0%200x2a0%200x00%200x00%200x00%200x57e%200xe4%200x294%200x00%200x00%200x00%200x57e%200xe0%200x290%200x00%200x00%200x00%200x57e%200xdc%200x28c%200x00%200x00%200x00%200x57e%200xd8%200x288%200x00%200x00%200x00%200x57e%200xec%200x29c%200x00%200x00%200x00%200x58e%200xe8%200x298%200x00%200x00%200x00%200x57e%200x7c%200x22c%200x00%200x00%200x00%200x91e%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%B3%E3%83%89%E3%83%AB%20%3D%26lt%3B0x3f%26gt%3B%20%EF%BF%BD%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CDIV%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%4042890000%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%2Cimx93-fec%22%2C%20%22fsl%2Cimx8mq-fec%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B0x42890000%200x10000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%26lt%3B0x00%200xb3%200x04%26gt%3B%E3%80%81%26lt%3B0x00%200xb4%200x04%26gt%3B%E3%80%81%26lt%3B0x00%200xb5%200x04%26gt%3B%E3%80%81%26lt%3B0x00%200xb6%200x04%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B0x07%200xb6%26gt%3B%E3%80%81%26lt%3B0x07%200xb6%26gt%3B%E3%80%81%26lt%3B0x07%200x5d%26gt%3B%E3%80%81%26lt%3B0x07%200x5f%26gt%3B%E3%80%81%26lt%3B0x07%200x60%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22ipg%22%E3%80%81%22ahb%22%E3%80%81%22ptp%22%E3%80%81%22enet_clk_ref%22%E3%80%81%22enet_out%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%94%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB-0%20%3D%26lt%3B0x3f%26gt%3B%20%EF%BF%BD%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-mode%20%3D%20%22rgmii-id%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-handle%20%3D%26lt%3B0x40%26gt%3B%20%40%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%40428a0000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22nxp%E3%80%81imx93-dwmac-eqos%5C0snps%E3%80%81dwmac-5.10a%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B0x428a0000%200x10000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%26lt%3B0x00%200xb8%200x04%200x00%200xb7%200x04%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E5%90%8D%20%3D%20%22macirq%5C0eth_wake_irq%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B0x07%200xb7%200x07%200xb7%200x07%200x5e%200x07%200x5c%200x07%200xb7%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22stmmaceth%5C0pclk%5C0ptp_ref%5C0tx%5C0mem%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B0x07%200x5e%200x07%200x5c%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%20%26lt%3B0x07%200x06%200x07%200x04%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20%26lt%3B0x5f5e100%200xee6b280%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eintf_mode%20%3D%20%26lt%3B0x27%200x28%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esnps%E3%80%81clk-csr%20%3D%26lt%3B0x05%26gt%3B%20%26%235%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Envmem-cells%20%3D%26lt%3B0x42%26gt%3B%20B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Envmem-cell-names%20%3D%20%22mac-address%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%94%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB-0%20%3D%26lt%3B0x43%26gt%3B%20C%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-mode%20%3D%20%22rgmii%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-handle%20%3D%26lt%3B0x44%26gt%3B%20D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%B3%E3%83%89%E3%83%AB%20%3D%26lt%3B0xb3%26gt%3B%20%EF%BF%BD%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%AA%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22snps%2Cdwmac-mdio%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%BB%E3%83%AB%20%3D%26lt%3B0x01%26gt%3B%20%26%231%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%E3%82%BB%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%26lt%3B0x00%26gt%3B%20%26%230%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B0xf4240%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%400%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy-ieee802.3-c22%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%26lt%3B0x00%26gt%3B%20%26%230%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eeee-%E5%A3%8A%E3%82%8C%E3%81%9F-1000t%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88gpios%20%3D%20%26lt%3B0x13%200x07%200x01%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B0x2710%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%87%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B0x186a0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emxl-8611x%E3%80%81led0_cfg%20%3D%20%26lt%3B0x2600%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emxl-8611x%E3%80%81led1_cfg%20%3D%26lt%3B0x70%26gt%3B%20p%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%B3%E3%83%89%E3%83%AB%20%3D%26lt%3B0x44%26gt%3B%20D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%405%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy-ieee802.3-c22%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%26lt%3B0x05%26gt%3B%20%26%235%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88gpios%20%3D%20%26lt%3B0x15%200x1b%200x01%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B0x2710%26gt%3B%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%87%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B0x13880%26gt%3B%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%B3%E3%83%89%E3%83%AB%20%3D%26lt%3B0x40%26gt%3B%20%40%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2290439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ethernet%20phy-reset%20using%20GPIO%20pin%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2290439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFVariscite%E3%81%AEVAR-SOM-MX93%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20BSP%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81Variscite%20%E3%81%AE%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2290435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ethernet%20phy-reset%20using%20GPIO%20pin%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2290435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258602%22%20target%3D%22_blank%22%3E%40Eduardo-S-Oliveira%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ENXP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E3%82%88%E3%82%8A%E9%81%A9%E5%88%87%E3%81%AB%E5%88%86%E6%9E%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%81%A9%E3%81%AE%20BSP%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E3%82%88%E3%82%8A%E5%8A%B9%E6%9E%9C%E7%9A%84%E3%81%AB%E8%AA%BF%E6%9F%BB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ethernet%20phy-reset%20using%20GPIO%20pin%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258602%22%20target%3D%22_blank%22%3E%40Eduardo-S-Oliveira%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%A7%8B%E6%88%90%E8%87%AA%E4%BD%93%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81PHY%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20GPIO%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%E3%83%8F%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%83%8E%E3%83%BC%E3%83%89%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%405%20%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ereset-gpios%20%3D%20%26lt%3B0x15%200x1b%200x00%26gt%3B%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E3%20%E7%95%AA%E7%9B%AE%E3%81%AE%E5%80%A4%20(0x00)%20%E3%81%AF%20GPIO_ACTIVE_HIGH%20%E3%82%92%E7%A4%BA%E3%81%97%E3%80%81GPIO%20%E3%81%8C%E3%83%8F%E3%82%A4%E3%81%AB%E9%A7%86%E5%8B%95%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%20PHY%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%E3%83%AD%E3%83%BC%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E8%A1%8C%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ereset-gpios%20%3D%20%26lt%3B0x15%200x1b%200x01%26gt%3B%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20GPIO%20%E3%81%8C%20GPIO_ACTIVE_LOW%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E4%BF%A1%E5%8F%B7%E3%81%8C%E4%BD%8E%E3%81%8F%E9%A7%86%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EPHY%20%E5%81%B4%E3%81%A7%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%8B%95%E4%BD%9C%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
