error : QA Issue: libpqxx.pc failed sanity test (tmpdir) in path
3,766件の閲覧回数
vladzouth
hi, i would like to build libpqxx (https://github.com/jtv/libpqxx) for my karo target(TX6S-8035). i use karo BSP (https://github.com/karo-electronics/meta-karo). i am facing some issue( error : QA Issue: libpqxx.pc failed sanity test (tmpdir) in path). Anyone can help me fix this. thanks in advance. Here is my libpqxx.bb file (https://pastebin.com/LcjrM47S) and my log.do_populate_sysroot file (https://pastebin.com/Ny2UT6yn)
Best Reagrds,
vladzouth
3,400件の閲覧回数
gusarambula
Hello Vladzouth,
The TX6S-8035 board is supported by Ka-Ro Electronics so I would recommend looking for support on their BSP directly with them. Before doing so I would recommend making a cleanall and trying again just in case there was a problem on the first bitbake.
3,400件の閲覧回数
vladzouth
Thank you for your information gusarambula ! I find a way to work around this issue by desabling pkgconfig.
