eglChooseConfig failed
saurabh206
Senior Contributor III
On our custom hardware based on IMX6q we are getting egl error frequently.
How can i fix this issue?
Please check the following crash log.
E/AndroidRuntime( 8727): FATAL EXCEPTION: main
E/AndroidRuntime( 8727): java.lang.IllegalArgumentException: eglChooseConfig failed EGL_SUCCESS
E/AndroidRuntime( 8727):     at android.view.HardwareRenderer$GlRenderer.chooseEglConfig(HardwareRenderer.java:1088)
E/AndroidRuntime( 8727):     at android.view.HardwareRenderer$GlRenderer.loadEglConfig(HardwareRenderer.java:1050)
E/AndroidRuntime( 8727):     at android.view.HardwareRenderer$GlRenderer.initializeEgl(HardwareRenderer.java:1035)
E/AndroidRuntime( 8727):     at android.view.HardwareRenderer$GlRenderer.initialize(HardwareRenderer.java:979)
E/AndroidRuntime( 8727):     at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1536)
E/AndroidRuntime( 8727):     at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1004)
E/AndroidRuntime( 8727):     at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:5481)
E/AndroidRuntime( 8727):     at android.view.Choreographer$CallbackRecord.run(Choreographer.java:749)
E/AndroidRuntime( 8727):     at android.view.Choreographer.doCallbacks(Choreographer.java:562)
E/AndroidRuntime( 8727):     at android.view.Choreographer.doFrame(Choreographer.java:532)
E/AndroidRuntime( 8727):     at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:735)
E/AndroidRuntime( 8727):     at android.os.Handler.handleCallback(Handler.java:730)
E/AndroidRuntime( 8727):     at android.os.Handler.dispatchMessage(Handler.java:92)
E/AndroidRuntime( 8727):     at android.os.Looper.loop(Looper.java:137)
E/AndroidRuntime( 8727):     at android.app.ActivityThread.main(ActivityThread.java:5103)
E/AndroidRuntime( 8727):     at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 8727):     at java.lang.reflect.Method.invoke(Method.java:525)
E/AndroidRuntime( 8727):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
E/AndroidRuntime( 8727):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
E/AndroidRuntime( 8727):     at dalvik.system.NativeStart.main(Native Method)
W/ActivityManager( 2695):   Force finishing activity com.android.settings/.Settings
Original Attachment has been moved to: egl_crash.log.zip
saurabh206
I have fixed this issue by increasing fbmem size.
Saurabh
saurabh206
Saurabh
