eIQ export TFLite model, output format can't got the correct finish the inference
1,325 次查看
HenryYeh
because we would like to deploy the TF Lite model into our edge device (iMX8M Plus EVK), and we following the guide for the model training, but we cannot show the result successful.
I've used the Model tool to check the in/output result.
also compare with the Google example,
2024-03-14 11_43_29-Chat _ iMx8 Study Regular Meeting. _ NXP _ henry.yeh_1@nxp.com _ Microsoft Teams.jpg
and saw the model from eIQ export was 'MLIR' , but the Google's one was TOCO, not sure it was any impact or how to transfer that.
3 回复数
1,235 次查看
HenryYeh
 I installed the eIQ(1.8) and used the default model (path: workspace\models\mobilenet_ssd_v3\)
then using the model tool to check the result (in/output)
but I try to used the eIQ training model (tflite) but show different output filed.
1,220 次查看
brian14
Hi @HenryYeh
Thank you for your reply.
In this case you will need to export the model after the training process.
1,283 次查看
brian14
Hi @HenryYeh
Could you please point to the Google's example that you used?
