dynamic/changeable boot command line
3,030件の閲覧回数
chris321
Hello community,
I want to use the imx28evk with an 2.6.35 Kernel.
I know how I can change the Linux kernel boot command line and this requires a rebuild of the boot stream.
But now I want to change the boot command line out of the target, like in a desktop linux a grub/lilo config file.
The goal of this is, that we can change the boot stream and the rootfs dynamically.
Is this possible (with/without) uboot?
best regards
ラベル(2)
2,859件の閲覧回数
JackyAtFreescal
Senior Contributor II
From my understanding, the kernel command line cannot be changed at run time for i.MX28.
https://community.nxp.com/message/312802/edit" style="font-style: inherit; font-family: inherit; col...
2,859件の閲覧回数
YixingKong
Senior Contributor IV
Chris321, did Jacky1z answer your question? If yes, please click Correct Answer button, so that your DI will be closed.
2,859件の閲覧回数
JackyAtFreescal
