difference between lib
已解决
跳至解决方案
4,101 次查看
garyyin
In the rootfs/usr/lib generated by yocto 3.14.28. I found several versions of libGLES:
libGLES_CL.so
libGLES_CM.so
libGLESv1_CL.so
libGLESv1_CM.so
libGLESv2.so
What's the difference between these 3 versions?
What's the difference between xx_CL.so & xx_CM.so?
1 解答
3,887 次查看
Hi Gary
for libs description please refer to attached Linux Manual
Table 13-2. GPU Library Files.
在原帖中查看解决方案
1 回复
3,888 次查看
Hi Gary
