/dev/snd/pcmC0D0p failed: Device or resource busy in Android 9 Automotive HFP
3,194 次查看
vinothkumars
Senior Contributor IV
Dear NXP,
Board: IMX8QM-MEB
OS: Android 9 Automotive
When in BT Call I got the following error continuously,
       can not open /dev/snd/pcmC0D0p failed: Device or resource busy.
My question is which card is used for HFP in IMX8QM-MEK Android 9 Automotive ?
XTOR, CS422888, WM8960.
Please provide the HFP stream follow for Android 9 Automotive ?
Thanks & Regards,
Vinothkumar Sekar
3,163 次查看
vinothkumars
Hi, My question is which card is used for HFP in IMX8QM-MEK Android 9 Automotive ?
Vinothkumar Sekar
3,132 次查看
AldoG
BT HFP should use dummy machine driver imx-xtor.c this will route audio to the real audio codec which for i.MX8QM MEK should be WM8960.
Aldo.
3,127 次查看
vinothkumars
Thank you for the reply nxf46838
audio_hw_primary: cannot open pcm_out driver 0: cannot open device '/dev/snd/pcmC0D0p': Device or resource busy
Will you please tell me how to resolve this issue.
Vinothkumar Sekar
