/dev/mxc_vpu can not be generated
1,633件の閲覧回数
824497590
I'm currently using the 4.9.11 kernel,i found that it  can not generated /dev/mxc_vpu,When my kernel version is higher than 4.9.11, both can not generated mxc_vpu device node, where do I need special configuration.
2 返答(返信)
1,623件の閲覧回数
joanxie
what board are you using? and what is your request? do you need test vpu?
1,617件の閲覧回数
824497590
是pmic影响到vpu节点的生成了 ,不过为什么影响我没有搞清楚,现在已经正常了
