change default fdt file imx8 in u-boot
1,317 次查看
Ahelion
Hello all, how do I change which .dtb file is the default one in yocto build for imx8qm?
i need the imx8qm-mek-rpmsg.dtb file to be default when I build.
Br,
标记 (1)
1 回复
1,294 次查看
JorgeCas
To use the "imx8qm-mek-rpmsg.dtb" as default dtb you need to specify your dtb name in "u-boot-imx/include/configs/imx8qm_mek.h" file.
Below the #define CONFIG_EXTRA_ENV_SETTINGS, there is fdt_file variable defined. Assign your mentioned dtb to that variable.
fdt_file=imx8qm-mek-rpmsg.dtb\0
Best regards.
