can we use malloc before mqx_init
2,506 次查看
josephxavier
can we use malloc before mqx_init in mqx 4.0
2,239 次查看
Hi welwin
please look at attached MQX Guide, FAQ sect.6.3 Global Constructors
describing malloc usage.
2,239 次查看
josephxavier
Initialize the constructors from (in init_bsp.c),
which MQX calls after it
initializes the memory management component.
is the solution that u proposed .
I tried to edit the start up .c but couldn't . eventhough I edited ,saved and build BSP ,PSP and project.
while debugging it again goes to static initializer for cpp which I had commented .
so could u share the steps to edit the startup.c in mqx project and bring it to effect .
I also tried to allocate static heap in linker, can this problem be over come by that method . can u share the steps while using fresscale compiler and ewl lib
