building GNOME rootfs for imx23
933 次查看
danix
Hey all, I tried to build fsl gnome_release for my imx23 based custom board. The build was successfull, but with a rootfs of around 600MB!
is this the normal size?
Other thing, once I built gnome and all the other packages it depends on, I couldn't remove it from rootfs and ltib configuration. I tried to remove the rootfs and rpm directories and build LTIB again, but it builds gnome evenif I don't select it...
标记 (1)
0 回复数
