build own linux kernel fails
floriankoenig
hi,
i try to build a linux kernel from my own sources. I created a kernel.bb file in mylayer/recipes-kernel/linux/   created a directory mylayer/recipes-kernel/linux/files  where i put the kernel.zip file ,the defconfig file and the Fix-the-compile-issue-under-gcc6.patch.
Inside the kernel.bb file i put
SRC_URI = "file://kernel.zip file://Fix-the-compile-issue-under-gcc6.patch  file://defconfig"
S = "${WORKDIR}/my-unpacked-kernel-dir-name"
B = "${WORKDIR}/build"
SCMVERSION = "n"
COMPATIBLE_MACHINE = "(mx6)"
But when i run bitbake virtual/kernel it returns:
recipe for target 'kernel/timeconst.h' failed
recipe for target "kernel" failed
what do i miss ?
Labels (3)
gusarambula
Helo Florian Koenig,
Did you add your new layer to the bblayers.conf list and can you see the new kernel recipe on bitbake? The reason why I’m asking is that it’s possible that there are problems with who provides the kernel on your environment. If bitbake can see the recipe, have you tried baking it directly?
