bt audio error
bt audio error
4,578 次查看
xrztech_wen
Hi,all,
     we use BT headset,while listening music,sometimes it would report below error :
E/audio_a2dp_hw( 1964): start_audio_datapath: audiopath start failed
I/audio_a2dp_hw( 1964): start_audio_datapath: state 3
D/LOGGER  ( 2452): gethostbyname(scs.openspeech.cn) start
D/LOGGER  ( 2452): gethostbyname(scs.openspeech.cn) ret=0, errno=0, h_errno=166
E/audio_a2dp_hw( 1964)rfkill: BT RF going to : off
I/audio_a2dp_hw( 1964): out_set_parameters: state 3
W/AudioTrack( 2452): dead IAudioTrack, PCM, creating a new one from obtainBuffer()
D/A2dpStateMachine( 2480): Connection state 00:02:5B:27:BC:A6: 2->0
D/CachedBluetoothDevice( 2601): onProfileStateChanged: profile A2DP newProfileState 0
D/BluetoothAdapterProperties( 2480): CONNECTION_STATE_CHANGE: 00:02:5B:27:BC:A6: 2 -> 0
D/PhoneStatusBarPolicy( 2348): shy SYstemUI PhoneStatusBarPolicy action=android.bluetooth.adapter.action.CONNECTION_STATE_CHANGED
D/CachedBluetoothDevice( 2601):  BT Turninig Off...Profile conn state change ignored...
D/bt_hci_bdroid( 2480): cleanup
W/bt-btif ( 2480): ag scb idx 1 not allocated
E/bt-btif ( 2480): BTA AG is already disabled, ignoring ...
W/bt-l2cap( 2480): L2CAP - PSM: 0x0019 not found for deregistration
W/bt-l2cap( 2480): L2CAP - PSM: 0x0017 not found for deregistration
I/bt_hci_bdroid( 2480): bt_hc_worker_thread exiting
W/bt_userial( 2480): select_read return size <=0:-1, exiting userial_read_thread
I/bt_userial_vendor( 2480): device fd = 69 close
D/BTSNOOP-DISP( 2480): btsnoop_close
D/bt_hci_bdroid( 2480): wen  set_power 0
I/GKI_LINUX( 2480): gki_task_entry: gki_task task_id=0 [BTU] terminating
I/GKI_LINUX( 2480): GKI_exit_task: GKI_exit_task 0 done
I/GKI_LINUX( 2480): GKI_destroy_task: GKI_shutdown(): task [BTU] terminated
D/BluetoothAdapterState( 2480): CURRENT_STATE=PENDING, MESSAGE = DISABLED, isTurningOn=false, isTurningOff=true
D/HeadsetService( 2480): Received stop request...Stopping profile...
D/BluetoothHeadset( 2297): Proxy object disconnected
D/A2dpService( 2480): Received stop request...Stopping profile...
D/A2dpStateMachine( 2480): Exit Disconnected: -1
D/BluetoothA2dp( 2297): Proxy object disconnected
D/BluetoothAdapterService( 2480): Profile still running: com.android.bluetooth.hdp.HealthService
W/BluetoothHeadsetServiceJni( 2480): Cleaning up Bluetooth Handsfree Interface...
W/BluetoothHeadsetServiceJni( 2480): Cleaning up Bluetooth Handsfree callback object
D/BluetoothAdapterState( 2480): Stopping profile services that were post enabled
D/HidService( 2480): Received stop request...Stopping profile...
D/HealthService( 2480): Received stop request...Stopping profile...
E/bt-btif ( 2480): warning : no command pending, ignore ack
I/GKI_LINUX( 2480): gki_task_entry: gki_task task_id=2 [A2DP-MEDIA] terminating
I/GKI_LINUX( 2480): GKI_exit_task: GKI_exit_task 2 done
I/GKI_LINUX( 2480): GKI_destroy_task: GKI_shutdown(): task [A2DP-MEDIA] terminated
D/BluetoothHeadset( 2601): Proxy object disconnected
D/PanService( 2480): Received stop request...Stopping profile...
D/BluetoothTethering( 2297): got CMD_CHANNEL_DISCONNECTED
E/BluetoothTethering( 2297): attempted to stop reverse tether with nothing tethered
D/BtGatt.DebugUtils( 2480): handleDebugAction() action=null
D/BtGatt.GattService( 2480): Received stop request...Stopping profile...
D/BtGatt.GattService( 2480): stop()
D/HeadsetProfile( 2601): Bluetooth service disconnected
D/BluetoothMapService( 2480): Received stop request...Stopping profile...
D/BluetoothMapService( 2480): stop()
D/BluetoothMapService( 2480): MAP Service closeService in
W/BluetoothHidServiceJni( 2480): Cleaning up Bluetooth HID Interface...
W/bt-btif ( 2480): cleanup: HH disabling or disabled already, status = 0
W/BluetoothHidServiceJni( 2480): Cleaning up Bluetooth GID callback object
D/BluetoothAdapterService( 2480): Profile still running: com.android.bluetooth.map.BluetoothMapService
W/BluetoothHealthServiceJni( 2480): Cleaning up Bluetooth Health Interface...
W/BluetoothHealthServiceJni( 2480): Cleaning up Bluetooth Health object
W/BluetoothPanServiceJni( 2480): Cleaning up Bluetooth PAN Interface...
W/BluetoothPanServiceJni( 2480): Cleaning up Bluetooth PAN callback object
D/BluetoothA2dp( 2601): Proxy object disconnected
D/A2dpProfile( 2601): Bluetooth service disconnected
D/BluetoothAdapterState( 2480): CURRENT_STATE=PENDING, MESSAGE = STOPPED, isTurningOn=false, isTurningOff=true
D/BluetoothAdapterProperties( 2480): Setting state to 10
I/BluetoothAdapterState( 2480): Bluetooth adapter state changed: 13-> 10
D/BluetoothAdapterService( 2480): Broadcasting updateAdapterState() to 1 receivers.
D/BluetoothManagerService( 2297): Message: 60
D/BluetoothManagerService( 2297): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 13, newState=10
D/BluetoothManagerService( 2297): Broadcasting onBluetoothStateChange(false) to 9 receivers.
D/BluetoothPbap( 2601): onBluetoothStateChange: up=false
I/BluetoothAdapterState( 2480): Entering OffState
D/BluetoothHeadset( 2601): onBluetoothStateChange: up=false
D/BluetoothMapService( 2480): cleanup()
D/BluetoothA2dp( 2601): onBluetoothStateChange: up=false
D/BluetoothInputDevice( 2601): onBluetoothStateChange: up=false
D/BluetoothInputDevice( 2601): Proxy object disconnected
D/HidProfile( 2601): Bluetooth service disconnected
D/BluetoothPan( 2601): BluetoothPAN Proxy object disconnected
D/PanProfile( 2601): Bluetooth service disconnected
D/BluetoothMap( 2601): Proxy object disconnected
D/MapProfile( 2601): Bluetooth service disconnected
D/BluetoothA2dp( 2297): onBluetoothStateChange: up=false
D/BluetoothHeadset( 2297): onBluetoothStateChange: up=false
D/BluetoothMap( 2601): onBluetoothStateChange: up=false
D/BluetoothManagerService( 2297): Calling onBluetoothServiceDown callbacks
D/BluetoothManagerService( 2297): Broadcasting onBluetoothServiceDown() to 5 receivers.
D/BluetoothManagerService( 2297): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@415acec0 mBinding = false
D/BluetoothManagerService( 2297): Sending unbind request.
D/BluetoothAdapterService( 2480): Cleaning up adapter native....
I/GKI_LINUX( 2480): gki_task_entry: gki_task task_id=1 [BTIF] terminating
I/GKI_LINUX( 2480): GKI_exit_task: GKI_exit_task 1 done
I/GKI_LINUX( 2480): GKI_destroy_task: GKI_shutdown(): task [BTIF] terminated
I/BluetoothServiceJni( 2480): cleanupNative: return from cleanup
D/BluetoothAdapterService( 2480): Done cleaning up adapter native....
D/BluetoothAdapterService(1094876728)( 2480): ****onDestroy()********
D/BluetoothManagerService( 2297): Bluetooth State Change Intent: 13 -> 10
D/BluetoothAdapter( 2348): 1094472592: getState() :  mService = null. Returning STATE_OFF
E/audio_a2dp_hw( 1964): a2dp_command: cmd failed (Broken pipe)
I/audio_a2dp_hw( 1964): skt_disconnect: fd 15
D/PhoneStatusBarPolicy( 2348): shy SYstemUI PhoneStatusBarPolicy action=android.bluetooth.adapter.action.STATE_CHANGED
D/BtGatt.GattService( 2480): cleanup()
W/bt-btif ( 2480): GATTC Module not enabled/already disabled
W/bt-btif ( 2480): GATTS Module not enabled/already disabled
W/ContextImpl( 2601): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1479
android.content.ContextWrapper.startService:494 android.content.ContextWrapper.startService:494
com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
D/DockEventReceiver( 2601): finishStartingService: stopping service
D/BluetoothAdapter( 2601): 1094485432: getState() :  mService = null. Returning STATE_OFF
I/str_params( 1964): key: 'exiting' value: '1'
I/str_params( 1964): key: 'closing' value: 'true'
E/audio_a2dp_hw( 1964): out_write: stream not in stopped or standby
I/audio_a2dp_hw( 1964): out_set_parameters: state 2
W/AudioSystem( 2452): ioConfigChanged() closing unknown output! 133
I/audio_a2dp_hw( 1964): adev_close_output_stream: closing output (state 2)
I/audio_a2dp_hw( 1964): stop_audio_datapath: state 2
I/audio_a2dp_hw( 1964): skt_disconnect: fd -1
D/MscSpeechLog( 2452): play stoped
D/PcmPlayer( 2452): play mPlaytate= 0,mAudioFocus= true
D/MscSpeechLog( 2452): tts start:1464676596985
D/PcmPlayer( 2452): start player
D/PcmPlayer( 2452): mAudioFocus= true
D/PcmPlayer( 2452): prepAudioPlayer || audiotrack stream type is change.
D/PcmPlayer( 2452): createAudio start
D/PcmPlayer( 2452): createAudio || mStreamType = 3
D/PcmPlayer( 2452): createAudio end
D/MscSpeechLog( 2452): minPlaySec:0
D/MscSpeechLog( 2452): curStatus=init,setStatus=start
D/MscSpeechLog( 2452): setStatus success=start
D/MscSpeechLog( 2452): startSpeaking NextSession pause
D/MscSpeechLog( 2452): tts msg start:1464676596992
D/MSC_LOG ( 2452): QTTSSessionBegin Begin
D/LOGGER  ( 2452): luacFramework_GetEnv() [in]
D/LOGGER  ( 2452): luacFramework_SetEnv() [out]
D/MSC_LOG ( 2452): QTTSSessionBegin End
D/MscSpeechLog( 2452): QTTSSessionBegin leave:25 ErrorCode:0
D/MscSpeechLog( 2452): QTTSTextPut enter
D/MSC_LOG ( 2452): QTTSTextPut Begin
D/MSC_LOG ( 2452): QTTSTextPut End
D/MscSpeechLog( 2452): QTTSTextPut leavel:0
D/MscSpeechLog( 2452): curStatus=start,setStatus=waitresult
D/MscSpeechLog( 2452): setStatus success=waitsresult
How to solve this problem?
BTW:
1.my BSP version is:
    android_kk4.4.2_1.0.0-ga_core_source.tar.gz+android_kk4.4.2_1.0.0-ga_epdc-patch.zip+DDR3 PATCH(imx_3.0.35_kk4.4.2_ga.tgz)+KK4.4.2_1.0.0_Regal.tar.gz
标签 (2)
4 回复数
3,615 次查看
chandrasekharma
Hi all,
I am getting same error, While getting this log audio break observed in Bluetooth Speaker/Headset. Please suggest how to resolve this bluetooth error
BSP: android-5.0.2_r1 with freescale patches
Thanks & Regards,
M.CHANDRASEKHAR
3,615 次查看
xrztech_wen
    Does anyone knew how to solve this problem? it is very urgent.
Thanks very much for support!
3,615 次查看
Hi wen
it may be suggested to apply to vendor of BT chipset for
help and probably updated firmware.
3,615 次查看
xrztech_wen
Hi igor:
      you think it need upgrade the new firmware?
isnot BT application wrong?
Thanks.
