boot from SPI Flash on imx7d
1,358 次查看
hyoungkikim
hi experts
i want to boot from spi nor flash,  on imx7d  sabre board,
so  using MikroBus  i  attached a spi-nor flash, i modified u-boot ( 2022.04 version) to support that flash,  and i successfully read, update a spi-nor in u-boot,
from  a user guide , i know  imx7d can boot by spi,  but i know  not what part to change to boot from a spi flash  in u-boot
basically u-boot has SD-boot and qpsi configuration, i tried to use these configuration with fail
any  information will be of great help ,
thank you sincerely
标签 (1)
1 回复
1,334 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Your boot device is not supported on 7D-SDB, the boot device you are trying to use is:
6.6.5.4 Serial ROM through SPI. i.MX 7Dual Applications Processor Reference Manual, Rev. 1, 01/2018.
There should be another board with the BOOT_CFG available for Serial SPI and make sure that the boot image complies with Figure 6-38. CSPI flow chart.
