bitbake faile about tensorflow-lite-host-tools-native
7,550 次查看
lidongxu
I followed the normal construction steps of yocto and used bitbake imx image full - c population for the first time SDK compilation was successful(My operation steps are based on the attachment), but when I ran this command for the second time, it prompted me that there was an issue with tensorflow-lite-host-tools-native, May I ask how to solve this problem ?
标记 (1)
12 回复数
7,532 次查看
Zhiming_Liu
Hi @lidongxu
Try to cleanall this package and rebuild it again.
7,529 次查看
lidongxu
I have tried using bitbake -c cleanall and bitbake -c cleanstate ,bit -c clean, Then use bitbake tensorflow-lite-host-native , But getting the same error message.
7,526 次查看
Zhiming_Liu
Make sure you have installed all host packages in ubuntu, seems relates to pthread library,
$ sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential \
chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils \
iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev \
python3-subunit mesa-common-dev zstd liblz4-tool file locales -y
$ sudo locale-gen en_US.UTF-8
7,523 次查看
lidongxu
I have installed all of these because they can be successfully compiled the first time 。
7,500 次查看
Zhiming_Liu
Which Linux Distro you are using ? Ubuntu or other?
We recommand Ubuntu20.04+
7,494 次查看
lidongxu
i using Ubuntu 18.04
7,489 次查看
Zhiming_Liu
Please update your Ubuntu Version or try to update glibc version[not recommand].
7,487 次查看
lidongxu
Update the system? I don't understand why it was possible before, but it wasn't possible after the second compilation? If there are system issues, the first compilation should also be unsuccessful, right
7,485 次查看
Zhiming_Liu
1.The host requirement has written in guide:
2. If you have checked the error , all about pthread library compatible issue.
3.NXP can't control the tensorflow-lite-host-tools-native layer requirement, it needs glibc in Ubuntu20.04+. This is controlled by Google, this software is not maintained by NXP.
4. Each verison ofBSP, we all export SDK. The Ubuntu18.04 has lots of compatible issues when internal test.
5. Please refer the guide, update your Ubuntu version or use docker.
7,483 次查看
lidongxu
i using REV.LF 6.1.22, Also needed ubuntu 20.04?
7,482 次查看
Zhiming_Liu
7,480 次查看
lidongxu
I understand now, thank you very much for your help!
