azure cloud shell event monitor not showing received telemetry messages
2,421 次查看
vsuneja63
I could send telemetry messages by azure-iot-sdk-c iothub client. Could see the message count increasing on azure account but event monitoring on cloud shell is not happening. Running below command for event monitoring:
az iot hub monitor-events --hub-name {YourIoTHubName} --output table
I couldn't found any error, its just waiting for messages. Can you suggest something on the same?
标签 (1)
4 回复数
2,396 次查看
jamesbone
What NXP board are you using?  which Wifi device? and where do you download the Azure IOT SDK?
2,364 次查看
vsuneja63
Thanks!
Any suggestion on the issue. Looking forward for your response on the same.
2,385 次查看
vsuneja63
Thanks!
Using imx8mq evk with bsp 5.4 . connecting usb dongle with board for internet connectivity. Downloded azure SDK from github, adding path below:
https://github.com/Azure/azure-iot-sdk-c
I could send messages & could see the D2C message count increasing but not able to monitor event on cloud shell. Is there any way to monitor telemetry messages with exact message body?
2,407 次查看
vsuneja63
Any suggestion on the same or any other way to check data of telemetry message(Device to Cloud) on azure cloud?
