ahab_close error
ahab_close error
2,092 次查看
dd_neu
I'm getting the following error when trying to close my board. What would cause this error?
=> ahab_status
Lifecycle: 0x00000008, OEM Open
        No Events Found!
=> ahab_close
Warning: Please ensure your sample is in NXP closed state, OEM SRK hash has been fused,
         and you are able to boot a signed image successfully without any SECO events reported.
         If not, your sample will be unrecoverable.
Really perform this operation? <y/N>
y
Error: ele_forward_lifecycle: ret -5, life_cycle 0x8, response 0xbb29
Error in forward lifecycle to OEM closed
exit not allowed from main input shell.
I also tried using nxpele with similar results.
~/src/imx-yocto-bsp-secureboot/build/tmp/deploy/images/imx8ulp-lpddr4-evk/imx-boot-tools/files$ sudo /home/ddresser/src/venv/bin/nxpele -f mimx8ulp forward-lifecycle-update -l OEM_CLOSED
[sudo] password for ddresser:
ERROR:UUUState:Command FB:UCMD ele_message 0x80000000 0x20000 0602951708000000 failed with error code -1 (477ms since start, spsdk_uuu.py:106)
SPSDKError: SPSDK: ELE Message failed.
Command:         ELE_FWD_LIFECYCLE_UP_REQ - (0x95)
Command words:   2
Command data:    False
Response words:  2
Response data:   False
Response status: Failure
   Response indication: ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND - (0xbb)
   Response abort code: 0x0
1,121 次查看
luca_calligaris
Hi, we are experiencing exactly the same failure. Can you please share the solution with me?
1,635 次查看
devanlec
Hi, I'm seeing the same error code when attempting to forward the lifecycle from OEM open to OEM closed on an i.MX93 from userspace.
My current sequence is:
  1. Flash a secure boot image following the NXP security reference design with AHAB enabled and the kernel image in a signed container.
  2. From userspace, burn in SRKH efuses using the imx-secure-enclave library
  3. Attempt to forward the lifecycle to OEM closed now that the SRKH efuses are burned in.
    At this point, I see the 0xbb29 error and I have to reboot before I can successfully forward the lifecycle.
Is there a process that would allow burning in the SRKH efuses and forwarding the lifecycle in a single boot, or is it inherently necessary to reboot between these steps (maybe to clear the ELE lifecycle events from the initial boot without the SRKH fuses burned)?
2,051 次查看
Harvey021
I've replied back to you in system email.
Please let me know if you need further support.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2053283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eahab_close%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%85%B3%E9%97%AD%E6%88%91%E7%9A%84%E6%9D%BF%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3D%26gt%3B%20ahab_status%0ALifecycle%3A%200x00000008%2C%20OEM%20Open%0A%0A%0A%20%20%20%20%20%20%20%20No%20Events%20Found!%0A%3D%26gt%3B%20ahab_close%0AWarning%3A%20Please%20ensure%20your%20sample%20is%20in%20NXP%20closed%20state%2C%20OEM%20SRK%20hash%20has%20been%20fused%2C%20%0A%20%20%20%20%20%20%20%20%20and%20you%20are%20able%20to%20boot%20a%20signed%20image%20successfully%20without%20any%20SECO%20events%20reported.%0A%20%20%20%20%20%20%20%20%20If%20not%2C%20your%20sample%20will%20be%20unrecoverable.%0A%0AReally%20perform%20this%20operation%3F%20%3CY%3E%0Ay%0AError%3A%20ele_forward_lifecycle%3A%20ret%20-5%2C%20life_cycle%200x8%2C%20response%200xbb29%0AError%20in%20forward%20lifecycle%20to%20OEM%20closed%0Aexit%20not%20allowed%20from%20main%20input%20shell.%3C%2FY%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E8%BF%98%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20nxpele%EF%BC%8C%E7%BB%93%E6%9E%9C%E4%B9%9F%E5%B7%AE%E4%B8%8D%E5%A4%9A%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E~%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2Fimx8ulp-lpddr4-evk%2Fimx-boot-tools%2Ffiles%24%20sudo%20%2Fhome%2Fddresser%2Fsrc%2Fvenv%2Fbin%2Fnxpele%20-f%20mimx8ulp%20forward-lifecycle-update%20-l%20OEM_CLOSED%20%0A%5Bsudo%5D%20password%20for%20ddresser%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0AERROR%3AUUUState%3ACommand%20FB%3AUCMD%20ele_message%200x80000000%200x20000%200602951708000000%20failed%20with%20error%20code%20-1%20(477ms%20since%20start%2C%20spsdk_uuu.py%3A106)%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0ASPSDKError%3A%20SPSDK%3A%20ELE%20Message%20failed.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0ACommand%3A%20%20%20%20%20%20%20%20%20ELE_FWD_LIFECYCLE_UP_REQ%20-%20(0x95)%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0ACommand%20words%3A%20%20%202%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0ACommand%20data%3A%20%20%20%20False%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0AResponse%20words%3A%20%202%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0AResponse%20data%3A%20%20%20False%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0AResponse%20status%3A%20Failure%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20Response%20indication%3A%20ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND%20-%20(0xbb)%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20Response%20abort%20code%3A%200x0%20%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ahab_close%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%9C%A8%20i.MX93%20%E4%B8%8A%E5%B0%9D%E8%AF%95%E4%BB%8E%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E5%B0%86%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E4%BB%8E%20OEM%20%E6%89%93%E5%BC%80%E8%BD%AC%E5%88%B0%20OEM%20%E5%85%B3%E9%97%AD%E6%97%B6%EF%BC%8C%E7%9C%8B%E5%88%B0%E4%BA%86%E7%9B%B8%E5%90%8C%E7%9A%84%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%9B%AE%E5%89%8D%E7%9A%84%E9%A1%BA%E5%BA%8F%E6%98%AF%3C%2FP%3E%3COL%3E%3CLI%3E%E9%81%B5%E5%BE%AA%E6%81%A9%E6%99%BA%E6%B5%A6%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%EF%BC%8C%E5%9C%A8%E5%90%AF%E7%94%A8%20AHAB%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%88%B7%E6%96%B0%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%E6%94%BE%E5%85%A5%E7%AD%BE%E5%90%8D%E5%AE%B9%E5%99%A8%E4%B8%AD%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BB%8E%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%EF%BC%8C%E4%BD%BF%E7%94%A8%20imx-secure-enclave%20%E5%BA%93%E7%83%A7%E5%BD%95%20SRKH%20efuses%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20SRKH%20%E5%BC%95%E4%BF%A1%E7%83%A7%E6%AF%81%E5%90%8E%EF%BC%8C%E5%B0%9D%E8%AF%95%E5%B0%86%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E8%BD%AC%E5%88%B0%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%20OEM%E3%80%82%3CBR%20%2F%3E%E6%AD%A4%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%200xbb29%20%E9%94%99%E8%AF%AF%EF%BC%8C%E6%88%91%E5%BF%85%E9%A1%BB%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%EF%BC%8C%E6%89%8D%E8%83%BD%E6%88%90%E5%8A%9F%E6%8E%A8%E8%BF%9B%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%81%E8%AE%B8%E7%83%A7%E5%BD%95%20SRKH%20%E7%86%94%E4%B8%9D%E5%B9%B6%E5%9C%A8%E5%8D%95%E6%AC%A1%E5%90%AF%E5%8A%A8%E4%B8%AD%E8%BD%AC%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E7%9A%84%E8%BF%9B%E7%A8%8B%EF%BC%8C%E6%88%96%E8%80%85%E6%98%AF%E5%90%A6%E5%BF%85%E9%A1%BB%E5%9C%A8%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%E4%B9%8B%E9%97%B4%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%EF%BC%88%E5%8F%AF%E8%83%BD%E6%98%AF%E4%B8%BA%E4%BA%86%E5%9C%A8%E4%B8%8D%E7%83%A7%E6%AF%81%20SRKH%20%E7%86%94%E4%B8%9D%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E4%BB%8E%E5%88%9D%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%97%B6%E6%B8%85%E9%99%A4%20ELE%20%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E4%BA%8B%E4%BB%B6%EF%BC%89%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ahab_close%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%9C%A8%E7%B3%BB%E7%BB%9F%E9%82%AE%E4%BB%B6%E4%B8%AD%E5%9B%9E%E5%A4%8D%E4%BA%86%E6%82%A8%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%94%AF%E6%8C%81%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2320110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ahab_close%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2320110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E6%95%85%E9%9A%9C%E3%80%82%E8%83%BD%E5%90%A6%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
