adb device serial no issue
suryapradhan
Hi all,
I am using Android-marshmallow on IMX7D.
I got below observations at the time of using adb commands.
adb devices
????????     device
I am able to login to IMX7D board using "adb shell" .
But why its not showing any serial no.
"serial no" is required instead of " ????".
Any suggestion on this.
Thanks & regards
Surya
Labels (2)
diegoadrian
Are you using our Sabre-SD board and our Android BSP?
This is because I tested the Android image and it has the serial number using the adb tool. I don't have the same problem as you.
Diego.
