about uuu document
about uuu document
HEXER
Greetings community.
Am i the only one who thinks UUU pdf file's content has lots of grammatically incorrect sentences?
I don't want to be ungraceful. I am asking because i am also a non-native English speaker and i want to see correct sentences to improve/educate myself.
Best regards...
HEXER
I was referring to https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/imx-processors/140261/1/UUU.pdf
for example:
UUU design as common library and UI. So user can easily integrate into their tools with uuu library. UUU also easy run in any
scripts.
and
bootloader means bootable image, which included ROM required header. for imx6/7, it should be uboot.imx
generally. for imx8qxp\imx8qm\imx8mm\im8mq, it is flash.bin.
i find the sentences quite weird.
Mestkim
兄弟这个不是汉语拼音
Mestkim
I read the words, it is very clear.
And I also put the words into to word to check. Here is result. It seems no grammar issue there.
HEXER
It seems that the issue is my bad english.
Manuel_Salas
Hello @HEXER !
Could you please point to me what uuu.pdf are you referring?
And if you can point which sentences are incorrect.
Best regards.
