about gamma correction
2,138 次查看
linzhang
I wan't to implement a display contrast adjustment machanism in linear mode,  but I don't know how to do it.
according to Gamma correction on i.MX6 ,  following steps can do gamma correction:
1 - Declare a variable as mxcfb_gamma:
struct mxcfb_gamma fb_gamma;
2 - Enable the gama correction:
fb_gamma.enable = 1;
3 - Set the constk and slopek values, where i = 0 to 15 and x and y are respectively the new constk and slopek constant values:
fb_gamma.constk[i] = x;
fb_gamma.slopek[i] = y;
4 - Open the framebuffer device and call MXCFB_SET_GAMMA:
fd_fb = open("/dev/fb0", O_RDWR, 0)
ioctl(fd_fb, MXCFB_SET_GAMMA, &fb_gamma)
how do I choose the constk & slopek values to insure the contrast vary in linear mode?
1,851 次查看
b36401
For linear transfer function you can simply turn off gamma correction.
Victor
1,851 次查看
linzhang
how to turn off gamma correction?
after turning off,  how to adjust display's contrast in linear way?
Can you show me some example codes?
