Xen implementation on Imx8quadmax
4,850 次查看
Naresh123
Technical Support Request: Xen Hypervisor / Dom0 Boot Issues
1. Hardware Environment:
  • Module: Apalis iMX8 QuadMax 4GB (V1.1)
  • Carrier Board: Ixora V1.3A
  • Serial Connection: Using UART_A (Serial Debug Console) via RS232-to-USB converter.
2. Software Environment (Validated via Bitbake):
  • BSP Version: 6.4.0-devel (Kirkstone)
  • Kernel Version: 5.15.129-6.4.0
  • Xen Version: 4.16
3. Issue Description:
  • Issue A (Serial Console): The serial output is consistently garbled/unreadable even when set to 115200 baud, 8-N-1. I have checked my baud rate settings and physical wiring.
  • Issue B (Xen/Dom0): The system is not booting into the Xen Hypervisor. Commands like xl info fail with "cannot init xl context," and uname -r shows the standard Linux kernel running on bare metal.
4. Observations:
  • The Xen binary (xen-apalis-imx8) is present in the deploy folder but does not appear to be loaded by U-Boot.
  • Standard Linux boots successfully, but virtualization features are inaccessible.
5. Request:
  • Please provide the correct U-Boot environment settings for the Ixora 1.3A board to properly load the Xen hypervisor binary before the Dom0 kernel.
  • Guidance on why the serial console output remains garbled despite using standard 115200 settings.
    APALIS-IMX8-KIT
8 回复数
4,547 次查看
Shivu_Guru_24
hi @Naresh123  how you are enabling xen hypervisor ? can you share me the documnets
4,542 次查看
Naresh123
Hi @Shivu_Guru_24
I have added the xen in my yocto image and after the build , I have flash to my imx8 and for checking in serial port , with command xl info , it was showing no such directlory found.
4,533 次查看
Shivu_Guru_24
@Naresh123 I need to enable the xen support on latest Android kernel?
Can you please support how to enable documentation?
4,528 次查看
Naresh123
@Shivu_Guru_24
Did you build the yocto with added xen?
Are you able to see Dom0 and DomU?
Are you able to make partitions?
4,524 次查看
Shivu_Guru_24
@Naresh123 i have some questions
i need to run Android and Freertos as guest vm on top of hypervisor i am just exploring before starting
which yocto is having added xen
we need to enable xen manually, right?
I did not sync Yoto code if i sync latest Yocto how to enable xen?
after enabling it Linux acts as dom0 right?
we can run Android and freertos as guest (DOmU)
4,771 次查看
Naresh123
Hello @Zhiming_Liu
To clarify, I am using the official Toradex BSP 6.4.0 (Kirkstone), not the stock NXP release. This environment was built using the  toradex minimal image layers. Since this is a standard Toradex software/hardware combination (Apalis iMX8 on Ixora), I am looking for the specific U-Boot command sequence required by this BSP version to boot Xen.
4,577 次查看
Zhiming_Liu
Hi @Naresh123
If you are using Toradex BSP 6.4.0, we don't know the command you need on this BSP. It's not released from NXP.
Zhiming
4,780 次查看
Zhiming_Liu
Hi @Naresh123
Due to differences between Toradex's BSP and NXP's BSP, we are unable to provide precise assistance. Please seek help on the Toradex community.
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2326418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20Imx8quadmax%20%E4%B8%8A%E5%AE%9E%E7%8E%B0%20Xen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH3%20id%3D%22toc-hId-2028341207%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%20id%3D%22toc-hId-2028345293%22%3E%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%E8%AF%B7%E6%B1%82%EF%BC%9AXen%20%E8%99%9A%E6%8B%9F%E6%9C%BA%E7%9B%91%E6%8E%A7%E5%99%A8%2FDom0%20%E5%90%AF%E5%8A%A8%E9%97%AE%E9%A2%98%3C%2FH3%3E%3CP%3E%3CSTRONG%3E1.%E7%A1%AC%E4%BB%B6%E7%8E%AF%E5%A2%83%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%A8%A1%E5%9D%97%EF%BC%9A%3C%2FSTRONG%3EApalis%20iMX8%20QuadMax%204GB%20(V1.1)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E8%BD%BD%E6%9D%BF%EF%BC%9A%3C%2FSTRONG%3EIxora%20V1.3A%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E4%B8%B2%E8%A1%8C%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FSTRONG%3E%E9%80%9A%E8%BF%87%20RS232%20%E8%BD%AC%20USB%20%E5%8F%98%E6%B5%81%E5%99%A8%E4%BD%BF%E7%94%A8%20UART_A%EF%BC%88%E4%B8%B2%E8%A1%8C%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E2.%E8%BD%AF%E4%BB%B6%E7%8E%AF%E5%A2%83%EF%BC%88%E9%80%9A%E8%BF%87%20Bitbake%20%E9%AA%8C%E8%AF%81%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E6.4.0-devel%EF%BC%88Kirkstone%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E5.15.129-6.4.0%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EXen%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E4.16%20%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E3.%E9%97%AE%E9%A2%98%E6%8F%8F%E8%BF%B0%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%20A%EF%BC%88%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%E5%8D%B3%E4%BD%BF%E8%AE%BE%E7%BD%AE%E4%B8%BA%20115200%20%E6%B3%A2%E7%89%B9%E3%80%818-N-1%EF%BC%8C%E4%B8%B2%E8%A1%8C%E8%BE%93%E5%87%BA%E4%B9%9F%E6%80%BB%E6%98%AF%E5%87%BA%E7%8E%B0%E4%B9%B1%E7%A0%81%2F%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E3%80%82%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E6%B3%A2%E7%89%B9%E7%8E%87%E8%AE%BE%E7%BD%AE%E5%92%8C%E7%89%A9%E7%90%86%E7%BA%BF%E8%B7%AF%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%20B%20(Xen%2FDom0)%EF%BC%9A%3C%2FSTRONG%3E%E7%B3%BB%E7%BB%9F%E6%97%A0%E6%B3%95%E5%9C%A8%20Xen%20%E8%99%9A%E6%8B%9F%E6%9C%BA%E7%9B%91%E6%8E%A7%E5%99%A8%E4%B8%AD%E5%90%AF%E5%8A%A8%E3%80%82xl%20info%20%E7%AD%89%E5%91%BD%E4%BB%A4%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%98%BE%E7%A4%BA%22cannot%20init%20xl%20context%E3%80%81%22%20%E5%92%8C%20uname%20-r%20%E6%98%BE%E7%A4%BA%E8%A3%B8%E6%9C%BA%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%E6%A0%87%E5%87%86%20Linux%20%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E4.%E6%84%8F%E8%A7%81%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EXen%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%20(xen-apalis-imx8)%20%E5%AD%98%E5%9C%A8%E4%BA%8E%E9%83%A8%E7%BD%B2%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%8C%E4%BD%86%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E7%94%B1%20U-Boot%20%E5%8A%A0%E8%BD%BD%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%A0%87%E5%87%86%20Linux%20%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E8%99%9A%E6%8B%9F%E5%8C%96%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E5.%E8%AF%B7%E6%B1%82%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E8%AF%B7%E4%B8%BA%20Ixora%201.3A%20%E6%9D%BF%E6%8F%90%E4%BE%9B%E6%AD%A3%E7%A1%AE%E7%9A%84%20%3CSTRONG%3EU-Boot%20%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%3C%2FSTRONG%3E%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%20Dom0%20%E5%86%85%E6%A0%B8%E4%B9%8B%E5%89%8D%E6%AD%A3%E7%A1%AE%E5%8A%A0%E8%BD%BD%20Xen%20%E8%99%9A%E6%8B%9F%E6%9C%BA%E7%9B%91%E6%8E%A7%E5%99%A8%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%85%B3%E4%BA%8E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BD%BF%E7%94%A8%E6%A0%87%E5%87%86%20115200%20%E8%AE%BE%E7%BD%AE%E5%90%8E%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BE%93%E5%87%BA%E4%BB%8D%E6%98%AF%E4%B9%B1%E7%A0%81%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FAPALIS-IMX8-KIT%2Fpd-p%2FAPALIS-IMX8-KIT%22%20class%3D%22lia-product-mention%22%20data-product%3D%222887-1%22%20target%3D%22_blank%22%3Eapalis-imx8-kit%3C%2FA%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%AE%98%E6%96%B9%E7%9A%84%20%3CSTRONG%3EToradex%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%206.4.0%EF%BC%88Kirkstone%EF%BC%89%3C%2FSTRONG%3E%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E8%82%A1%E7%A5%A8%E7%89%88%E6%9C%AC%E3%80%82%E8%BF%99%E4%B8%AA%E7%8E%AF%E5%A2%83%E6%98%AF%E4%BD%BF%E7%94%A8%20toradex%20%E6%9C%80%E5%B0%8F%E5%9B%BE%E5%83%8F%E5%B1%82%E6%9E%84%E5%BB%BA%E7%9A%84%E3%80%82%E7%94%B1%E4%BA%8E%E8%BF%99%E6%98%AF%E6%A0%87%E5%87%86%E7%9A%84%20Toradex%20%E8%BD%AF%E4%BB%B6%2F%E7%A1%AC%E4%BB%B6%E7%BB%84%E5%90%88%EF%BC%88Ixora%20%E4%B8%8A%E7%9A%84%20Apalis%20iMX8%EF%BC%89%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%E8%BF%99%E4%B8%AA%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%E7%89%88%E6%9C%AC%E5%90%AF%E5%8A%A8%20Xen%20%E6%89%80%E9%9C%80%E7%9A%84%E7%89%B9%E5%AE%9A%20U-Boot%20%E5%91%BD%E4%BB%A4%E5%BA%8F%E5%88%97%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260399%22%20target%3D%22_blank%22%3E%40Naresh123%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E7%94%B1%E4%BA%8EToradex%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E5%92%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E4%B9%8B%E9%97%B4%E7%9A%84%E5%B7%AE%E5%BC%82%EF%BC%8C%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E6%8F%90%E4%BE%9B%E7%B2%BE%E7%A1%AE%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E8%AF%B7%E5%9C%A8%20Toradex%20%E7%A4%BE%E5%8C%BA%E5%AF%BB%E6%B1%82%E5%B8%AE%E5%8A%A9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260399%22%20target%3D%22_blank%22%3E%40Naresh123%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20%3CSTRONG%3EToradex%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%206.4.0%3C%2FSTRONG%3E%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B8%8D%E7%9F%A5%E9%81%93%E4%BD%A0%E5%9C%A8%E8%BF%99%E4%B8%AA%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%E4%B8%8A%E9%9C%80%E8%A6%81%E4%BB%80%E4%B9%88%E5%91%BD%E4%BB%A4%E3%80%82%E5%AE%83%E4%B8%8D%E6%98%AF%E7%94%B1%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8F%91%E5%B8%83%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260399%22%20target%3D%22_blank%22%3E%40Naresh123%3C%2FA%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%BC%80%E5%A7%8B%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E6%88%91%E5%88%9A%E5%88%9A%E6%8E%A2%E7%B4%A2%E7%9A%84%E8%99%9A%E6%8B%9F%E6%9C%BA%E7%9B%91%E6%8E%A7%E5%99%A8%E4%B9%8B%E4%B8%8A%E4%BB%A5%E8%AE%BF%E5%AE%A2%E8%99%9A%E6%8B%9F%E6%9C%BA%E7%9A%84%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%20Android%20%E5%92%8C%20Freertos%3C%2FP%3E%3CP%3E%E5%93%AA%E4%B8%AA%20yocto%20%E6%AD%A3%E5%9C%A8%E6%B7%BB%E5%8A%A0%20xen%20%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E6%89%8B%E5%8A%A8%E5%90%AF%E7%94%A8%20xen%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%B2%A1%E6%9C%89%E5%90%8C%E6%AD%A5%20Yoto%20%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%90%8C%E6%AD%A5%E6%9C%80%E6%96%B0%E7%9A%84%20Yocto%EF%BC%8C%E5%A6%82%E4%BD%95%E5%90%AF%E7%94%A8%20xen%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%90%AF%E7%94%A8%E4%B9%8B%E5%90%8E%20Linux%20%E4%BC%9A%E5%85%85%E5%BD%93%20dom0%20%E5%AF%B9%E5%90%A7%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BB%A5%E8%AE%BF%E5%AE%A2%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%20Android%20%E5%92%8C%20freertos%20(DOmU)%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260399%22%20target%3D%22_blank%22%3E%40Naresh123%3C%2FA%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E6%9C%80%E6%96%B0%E7%9A%84%E5%AE%89%E5%8D%93%E5%86%85%E6%A0%B8%E4%B8%8A%E5%90%AF%E7%94%A8%20xen%20%E6%94%AF%E6%8C%81%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E5%90%AF%E7%94%A8%E6%96%87%E6%A1%A3%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260363%22%20target%3D%22_blank%22%3E%40Shivu_Guru_24%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E6%88%91%E7%9A%84%20yocto%20%E9%95%9C%E5%83%8F%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%20xen%EF%BC%8C%E5%9C%A8%E7%89%88%E6%9C%AC%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E7%9A%84%20imx8%20%E4%B8%8A%E6%9C%89%E9%97%AA%E5%AD%98%E4%BA%86%EF%BC%8C%E4%B8%BA%E4%BA%86%E6%A3%80%E6%9F%A5%E4%B8%B2%E8%A1%8C%E7%AB%AF%E5%8F%A3%EF%BC%8C%E6%9C%89%E4%BA%86%E5%91%BD%E4%BB%A4%20xl%20%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E8%BF%99%E6%A0%B7%E7%9A%84%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260363%22%20target%3D%22_blank%22%3E%40Shivu_Guru_24%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E4%BD%A0%E6%98%AF%E7%94%A8%E6%B7%BB%E5%8A%A0%E7%9A%84%20xen%20%E7%9A%84%20yocto%20%E7%89%88%E6%9C%AC%20%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E8%83%BD%E7%9C%8B%E8%A7%81%20Dom0%20%E5%92%8C%20domU%20%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E8%83%BD%E5%81%9A%E5%88%86%E5%8C%BA%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Xen%20implementation%20on%20Imx8quadmax%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260399%22%20target%3D%22_blank%22%3E%40Naresh123%3C%2FA%3E%20%E4%BD%A0%E6%98%AF%E6%80%8E%E4%B9%88%E5%90%AF%E7%94%A8%20xen%20%E8%99%9A%E6%8B%9F%E6%9C%BA%E7%9B%91%E6%8E%A7%E5%99%A8%E7%9A%84%EF%BC%9F%E8%83%BD%E5%90%A6%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E6%96%87%E4%BB%B6%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
