Xen hypervisor with AGL and Android Automotive
3,832 次查看
vinothkumars
Senior Contributor IV
We are working on to port Xen hypervisor to the custom board with AGL as host and Android Automotive as Guest. We also need communication between the AGL and AA OS
Is that possible or do we need port Linux as host and AGL, AA as two guest OS?
Please suggest we need to initiate the design and proceed accordingly we believe AGL as host should be possible in that way we can also avoid one more OS footprint but we arent experts on this
Vinothkumar Sekar
3,671 次查看
ruisb
Hi Vinothkumars
I have the same question with you. Are you able to run AGL on Xen hypervisor as dom0 now? I need your experience!
Thanks in advance
Shibo
3,827 次查看
Zhiming_Liu
AGL is not in support list of i.MX8QM .If you port it on i.MX8QM, you will meet lots of issues.
