Windows Embedded compact 7 Silverlight app.
2,381件の閲覧回数
AshokAiyawar
Silverlight app for windows embedded compact 7 doesn't run on i.MX53 QSB. Built and deployed okay.
2 返答(返信)
2,243件の閲覧回数
AshokAiyawar
Hello Andrew, I just created a simple Hello world app in Expression Blend 3 and imported into VS2008, built the app and deployed the app to i.MX53 QSB using Activesync.Then, i went into i.MX53 QSB i was able to see the app. Double clicked on the icon, nothing happens. Thanks for your help.
2,243件の閲覧回数
iMXAndrew
Turn off activesync, do not include media files to be included, make sure you have windows embedded for silverlight included in you build. Also make sure you have control panel for silverlight included in your build. Are you using a wifi or bluetooth module?
