Why the whole file system keeps untouched after a restart
13614278
Hi there,
We're using IMX8mini EVK, with Yocto Linux.
Suppose I :
echo 'hello world' >/var/log/nginx/my.log
It goes fine during the daily use. But after I restart the system, the my.log file under /var/log/nginx/ would be missing.
Why each restart would cause the Linux file system back to the original status, without any files that the user created?
gusarambula
Hello Yang Songxiang,
It could be a problem of permissions from ngix. I would recommend looking for more details on the ngix documentation.
https://docs.nginx.com/nginx/admin-guide/monitoring/logging/
I would check that the echo actually wrote on the log as it could be that the operation wasn’t performed due to user restrictions. And then I would also check that the nginx process is running and has the appropriate permissions and settings.
