Why hdmi_enable_overflow_interrupts() will be called?
1,345件の閲覧回数
m_c
Senior Contributor I
Customer found this function is always been called when using DSI+HDMI and can't enter Android. After modify as below, then can enter Android.
static void hdmi_enable_overflow_interrupts(void)
        return;
        pr_debug("%s\n", __func__);
        hdmi_writeb(0, HDMI_FC_MASK2);
        hdmi_writeb(0, HDMI_IH_MUTE_FC_STAT2);
ラベル(2)
1,139件の閲覧回数
Hi Mike
please check
devuan-sdk/f922b0d.patch at master · dyne/devuan-sdk · GitHub
