Why Did NXP Suddenly Disable PCIe Advanced Error Reporting (AER)
5,150 次查看
marcelziswiler
Senior Contributor I
Why exactly did NXP suddenly disable PCIe Advanced Error Reporting (AER) in their latest Linux BSP LF5.15.52_2.1.0 (Sep 2022)? So far in previous BSPs you guys had this always enabled. Is there any issue with using it? Thanks!
7 回复数
4,991 次查看
marcelziswiler
So NXP is unable to answer our questions?
5,042 次查看
marcelziswiler
NXP dares to shed some light on this topic?
5,036 次查看
Rita_Wang
LF5.15.52 didn't disable PCIE  AER
5,044 次查看
marcelziswiler
NXP dares to share what is going on here?
5,107 次查看
Rita_Wang
I still not get the update from our expert, for the adding question you can use "pcie_ports=native"
5,124 次查看
Rita_Wang
Please refer to our newest released, details reason I will help confirm.
5,119 次查看
flaviosuligoi
any news about it?
Another question:
CONFIG_PCIEAER and CONFIG_PCIEAER_INJECT can be used for a production kernel?
I must also use "pcie_ports=native" as kernel parameter or it is unnecessary?
Flavio
