Where LOADADDR is being used?
4,119 次查看
maniam
I am following the instructions in this link to change the Linux kernel configuration in NITROGEN6X board from Boundary Devices. My question is about exporting the LOADADDR in line 6.
As far as I remember, LOADADDR variable is needed in creating a uImage in 'make uImage' command. But we are not making a uImage here. Where exactly the LOADADDR is being used? More specifically in which make command?
make zImage
make modules
make dtbs
make -C ubuntunize tarball
- Mani
标记 (1)
3,571 次查看
gary_bisson
Senior Contributor III
This post is outdated. The LOADADDR is indeed useless here. It will be updated within two weeks.
Gary
3,571 次查看
gusarambula
Hello Mani Amoozadeh,
Indeed zImage does not require the LOADADDR parameter as far as I know.
Perhaps it was kept there from previous documents from where this document is based. However, I would ask people from Boundary Devices to be sure.
gary_bisson would you know why this parameter (LOADADDR) is kept on the document below when making zImage?
https://boundarydevices.com/ubuntunizing-i-mx6-kernels/
3,572 次查看
gary_bisson
Gary
3,571 次查看
maniam
Thanks! I have one more question about the above commands. I have created a new question about it here: https://community.nxp.com/message/845384
